Electret opamp gain problem - diyAudio
Old 14th September 2012, 03:08 PM   #1
Default Electret opamp gain problem
Using the TL072 after another TL072 unity gain buffer, there is limited amplification regardless of what combination of resistors are used. I wish at least a gain of 10.
It will not go past about 2:1. I have to scream into the omni-directional element to get about 180mV. The output of the buffer is good. Power supply is -+ 12v. Several different amps were tried to eliminate any damaged units to no avail. Another copy of the same element was tried also to no avail. The output of the element at the blocking cap is about 3mV as always.
Here is the wiring used:Non-inverting opamp wiring.jpg
Can someone help me out of the Twilight Zone?
Old 14th September 2012, 03:31 PM   #2
diyAudio Member RIP
Can't see the point of the unity gain buffer, have you biased the capsule ?
rgds, sreten.
Simple Stereo Electret Mic Preamp
Old 14th September 2012, 06:53 PM   #3
The buffer was left over from an attempt to drive the resistors in a differential stage being fed from two elements, and is not needed at present.
The 2-terminal capsule is biased through a 2.2k resistor on the pos side (3v.) with the other grounded, and a DC blocking cap just before the output term. as per mfr's. recommendations.
As I see your circuit, the input is fed rail voltage. Then there is a cap blocking the 4.5v from the divider, which I guess is added because the amp is single rail. I don't understand why rail voltage is added to the input, or what the cap after it is doing.
The feedback circuit is rather complex. The 33k resistor is in parallel with a cap, and the rest of the resistors are not directly grounded, but instead go through another cap. I was wondering why all the components. If you could shed light, I would appreciate it. The switch is obviously a range selector. The rest of the circuit is rudimentary.
Old 14th September 2012, 08:34 PM   #4
nigelwright7557's Avatar
The switch needs to be closed to get decent gain.
Murton-Pike Systems PCBCAD51 pcb design software. http://www.murtonpikesystems.co.uk http://www.pcbcad51.co.uk
Old 15th September 2012, 01:09 AM   #5
Thank you everybody for your answers. It has come to me that at least the cap that is in parallel with the one feedback resistor forms a bandpass filter.
Well, I will build the circuit and see how it performs and eventually figure out (maybe) what the series cap does. I plan on using the ADI SSM2019 self-contained preamp which provides differential, anyway.
nigelwright7557 Speaking of gain, I trust you have Dimarzios on that axe!
Tally-ho....
Old 15th September 2012, 01:39 AM   #6
Tally-ho....
It is a completely original Peavey Patriot, I have had it for about 20 years and it still plays really well.
Gain Formula for Opamp Circuit luvdunhill Solid State 4 20th November 2012 02:29 PM
OpAmp based Summing circuit -- Is greater than Unity Gain here a technical problem? ryansupak Analog Line Level 5 9th July 2012 12:22 AM
Throwing away open loop gain with an opamp near or at unity gain okapi Pass Labs 3 25th December 2009 01:23 PM
Opamp confusion about gain sergiusz Chip Amps 8 4th March 2006 08:27 AM
+/-15Vout opamp for gain stage anli Solid State 14 10th December 2004 11:36 AM
Copyright 1999-2017 diyAudio
