What do you guys use to enclose your amps? - diyAudio
Old 13th September 2012, 11:19 PM   #1
Default What do you guys use to enclose your amps?
What kind of enclosures are you guys using for your amps? I see a lot of people using metal chassis but I have no idea how to do metalwork nor do I know where to get the raw materials. I'm decent at wood working but isnt it a bit weird to put pcbs, transformers and stuff in a wood enclosure?
Old 13th September 2012, 11:25 PM   #2
tvrgeek is offline tvrgeek  United States
Bud box, "rack" chassis, or for big bucks, nice pretty enclosures.
Is wood weird? No, that's where we started turn of the century. Even the Apple One was just a board screwed to a piece of plywood. Wood is not very good at RF shielding though. A bit of foil tape works like a charm.
Old 14th September 2012, 12:45 AM   #3
nigelwright7557's Avatar
For my larger amps I use a pc case.
They are cheap compared to other options.
It also has a mains socket punched out.
It has a fan housing front and back. I use the fans with LED's in them and they look flash.
Murton-Pike Systems PCBCAD51 pcb design software. http://www.murtonpikesystems.co.uk
Old 14th September 2012, 01:17 PM   #4
east electronics's Avatar
my latest enclosure
SERVICE ΕΝΙΣΧΥΤΩΝ ΚΑΙ ΙΑΠΩΝΙΚΩΝ ΜΗΧΑΝΗΜΑΤΩΝ ΗΧΟΥ www.eastelectronics.gr
Old 14th September 2012, 01:28 PM   #5
sakis. damn. so the UFO sitings is your amp that has been flying?
looks very nice
Old 14th September 2012, 01:33 PM   #6
Are you talking about tower/mini tower or desktop cases? Apart from a few holes to cover requiring minimal effort, that sounds like an excellent idea.
currentflow
Old 14th September 2012, 02:16 PM   #7
Skyjham is offline Skyjham  Philippines
here's mine, fabricated # 18 GI sheet with DIY yamaha main amp.
Old 14th September 2012, 02:19 PM   #8
indianajo's Avatar
You, sir, obviously have a $1500 shear, and probably a milling machine also.
I have an electric drill and a vise and a workbench.
For op amp projects like mixers or active filters, I use PCAT power supply boxes. They have the AC stuff already worked out. I have also built some low power supplies into them with transformers and the fan.
For bigger stuff, I have some VFD motor drive chassis in stainless steel boxes with a disconnect and a big aluminum neat sink on the back. You get these out of the dumpster at food factories. They blow them up a lot with the water hose. PCAT towers are good, but rather huge. Only one charity resale shop sells PC's in this county. Goodwill won't sell their donated PC's here, and it is illegal in Florida not to send them to the "recycle facility".
If you want more RF blocking than the stainless box can provide, salvage the heat sink and put it in a hinged top recipe case or file box. I get them for $2-#3 at the charity resale shop, or by the side of the road on garbage day. You can make odd size holes by drawing them out undersized with a sharpie marker, drilling a bunch of 1/8" holes in the outline with an electric drill, add one 3/8" hole in the middle. Then you connect the dots with an $8 Stanley carbide hacksaw blade in a $2 adjustable hacksaw frame. You do need a vise and a dirty workbench for this. Use safety glasses when drilling. Oh, holes over 1/2" dia are best made this way. The expensive 7/8 diameter bits etc with a 3/8" shank tend to break in sheet metal.
Dynakit ST70, ST120, PAS2,Hammond H182(2 ea),H112,A100,10-82TC,Peavey CS800S,1.3K, SP2-XT's, T-300 HF Proj's, Steinway console, Herald RA88a mixer, Wurlitzer 4500, 4300
Old 14th September 2012, 03:16 PM   #9
dadod is offline dadod  Croatia
dadod's Avatar
I use wood.
dado
Old 14th September 2012, 03:43 PM   #10
looks very nice
gratsias
How do you guys like the 'waffle amps'? chipper Car Audio 15 21st April 2011 04:12 AM
Hey Guys Are the Hlly tripath amps phillesgoal? fatbattery Solid State 0 5th April 2011 10:40 AM
What are you guys using for speakers with your amps? jduffy Chip Amps 20 23rd May 2008 12:17 AM
Active crossover guys.....what amps do you use? demon2091tb Multi-Way 58 28th November 2006 06:22 PM
Here is a great tip for you guys building aluminum chassis for your amps russbryant Pass Labs 39 28th November 2004 01:19 AM
Copyright 1999-2017 diyAudio
