What is a good way to measure peak watts I'm using during music?
Old 15th September 2012, 10:06 AM   #21
Most of us monitor voltage.
That is NOT the same as monitoring power!
To monitor power one must instananeously read both current and voltage at the load and then multiply the two readings/measurements, the result is instantaneous power delivered to the load.
There are IC chips that do that. But, in general they do not have a big range, unless they are very complicated and thus expensive.
Even our household electricity meters only monitor current and make an assumption on the supply voltage, to allow a read out in Power units.
As far as I have read in the above replies all have fallen into the trap that an assumption on resistance has been made without realising it. They all take the drive voltage and convert that to power using the standard formula: Power = Volts squared divided by load resistance. This ignores the variation in load resistance. That inadvertent assumption leads to gross errors in power readings.
regards Andrew T.
Old 15th September 2012, 12:15 PM   #22
forr is offline forr  France
forr's Avatar
Mutliply current and voltage and cosine of phase between both.
This is why, at low frequencies, there is not much power dissipated in the voice coils.
I am interested. Can you give some references ?
Old 15th September 2012, 03:57 PM   #23
DUG is offline DUG  Canada
AD633JRZ
In Digi-Key search for multiplier ic
Linear - Analog Multipliers, Dividers
then select 4-quadrant
learn well
Doug We are all learning...we can all help
"You can't stop the signal, Mal. Everything goes somewhere..."
Old 15th September 2012, 04:19 PM   #24
destroyer X is offline destroyer X  Brazil
destroyer X's Avatar
Default The way is to plug a scope, to read the peak to peak
and calculate.
Carlos
Dx unbeatable amplifiers; https://www.youtube.com/watch?v=u4tGBiqMnzQ
Old 15th September 2012, 04:29 PM   #25
you don't need cosine.
The instantaneous power is simply the current times the voltage at that instant.
regards Andrew T.
Old 15th September 2012, 04:40 PM   #26
and calculate.
No, that does not tell you or any one else the current.
P=IV
You need both to calculate power.
regards Andrew T.
Old 15th September 2012, 04:45 PM   #27
Pano is offline Pano  United States
Pano's Avatar
Yeah, with a digital source, it isn't that hard. Actually measuring the current and voltage, or finding a fast watt-meter is best, but you can get a very good idea just from measuring a test tone.
As for dynamics, most CDs don't have as much as you might think.* A typical ratio of average to peak is 18dB. Some better CDs will have 22dB or more range . If the recorded passage is lower than that, it probably is not meant to be loud. Think about it. Quiet passages are mot meant to be at 80dB SPL.
*I've analyzed about 16000 tracks. 16dB from average to peak is typical of good pop, jazz, rock. Classical and well mastered stuff can be at about 22dB peak/average. Recent "squashed" mastering is about 10dB below peak with a good bit of clipping.
Take the Speaker Voltage Test!
Old 15th September 2012, 07:42 PM   #28
Default All you need is a scope, the music playing and a scope
of course the knowledge how to measure is needed too.... you need speaker too
It is simple and there's no tips and tricks for that.
regards,
Carlos
Old 15th September 2012, 08:42 PM   #29
forr's Avatar
Instantaneous voltages and instantaneous currents are significant values.
Instantaneous powers are not. Electrical power needs some amount of time to show its effets.
Old 15th September 2012, 08:47 PM   #30
forr's Avatar
I collect this kind of data. Yours agree with others I already have.
What is a good way to measure peak watts I'm using during music?Hide this!Advertise here!
When companies state watts, is it rms or peak? Fusion916 Solid State 11 2nd March 2012 11:26 PM
compression driver peak music power testing Sanon Multi-Way 1 13th August 2011 10:59 AM
Spect output peak to peak for 807 SE ul walter807 Tubes / Valves 2 1st December 2010 12:24 PM
Good chip for 5 Watts or so into 8 Ohm? Omega_Void Chip Amps 7 29th October 2008 08:51 PM
free software to see/measure peak values? Theli Music 2 3rd January 2007 06:21 PM
