Musical fidelity A1 all recapped but sounds muffled
Old 13th September 2012, 07:37 PM   #1
cretaceous is offline cretaceous  United Kingdom
Default Musical fidelity A1 all recapped but sounds muffled
title says it all - I recapped it, replaced power transistors, psu diodes and a few burnt resistors
It certainly now sounds very smooth, but it's muffled - as if a loudness button is on and/or treble is turned down. It's been left on for plenty of spells of 4-6 hours now, but no improvement. It's the same on any input e.g cd or turntable.
When picking the caps I did not choose high quality audio spec - I did not realise it was important. (doh)
The ones I replaced did not have any fancy markings, so I used general electrolytics (but with better temp and voltage specs).
SO.. any ideas what I can change to improve things?
schematic is here:
Musical Fidelity A1 - Technical
Thanks!
Old 13th September 2012, 10:43 PM   #2
Nrik is offline Nrik  Denmark
You could parallel the electrolytics in the signal path with some MKT or MKP plastic film capacitors, that usually gives a more open sound and less muffle.
It would be C6, C7, C13 and C14. 100nF on each should do the trick
Henrik
Old 13th September 2012, 10:53 PM   #3
yagoolar is offline yagoolar  Poland
yagoolar's Avatar
Send a message via ICQ to yagoolar Musical fidelity A1 all recapped but sounds muffled
I replaced 10uF input el caps in MF elektra e10 with ERO MKT1813 6uF and then the amp started to sound open and detailed. Find my thread. There are pictures there. I would replace C6 and C7 with styroflex or some good MKT/P. Have you replaced PSU caps?
Thread link http://www.diyaudio.com/forums/showthread.php?t=218584
Old 13th September 2012, 11:12 PM   #4
thanks guys.. great I can try some things out
and yes I replaced the PSU caps - bent wire radials to replace unobtainable axials
Old 13th September 2012, 11:26 PM   #5
destroyer X is offline destroyer X  Brazil
destroyer X's Avatar
Default Mistakes in the capacitor values... for sure
Mufled sound use to be a result of increased capacitances in key points.
It will not be capacitor type or brand...will be values.... we can install 0.1uf (100n) in the place of 100pf by a mistake... as an example.
Check values first...then try other possibilities.
Do changes in one channel to compare...because we use to believe in things we previously believe...say.... if you try to replace a blue capacitor by a green capacitor..and you believe the green one is better quality one....then you will listen the green one sounding better...the only way not to be fooled by yourself is to compare with the other channel.
If we, humans, had the precision not to fool ourselves we would never believe in UFO and nor religions will be so important in our lives
regards,
Carlos
Old 13th September 2012, 11:32 PM   #6
I'm certain values are correct.. I took good care over that!
(I used to do a lot of diy projects many years ago..)
Old 13th September 2012, 11:34 PM   #7
reji is offline reji  India
what was the condition before recapping?
Old 13th September 2012, 11:36 PM   #8
Default I suggest you to make another check up
If you are not an exception... or a kind of extra terrestrial... then you can make mistakes...humans fails.
When we are old and skilled...and when we had assembled thousand amplifiers..then we think we cannot fail...and this is the moment we fail without the believe we can do it wrong way.
Good luck, and good bye.
regards,
Carlos
Old 14th September 2012, 12:14 AM   #9
tvrgeek is offline tvrgeek  United States
Is the temp OK Still stable?
Set the bias?
Polarity correct?
Do you have proper equipment to protect against ESD?
Any test equipment? Toss together a simple test rig and use ARTA to look at the response. Couple of zieners, couple of resisters and your sound card.
Old 14th September 2012, 01:36 AM   #10
5th element is offline 5th element  United Kingdom
5th element's Avatar
As Tvr says, measuring the frequency response of the amp is the only way to check if something major is awry. Changing capacitors shouldn't have caused the top end to get rolled off, but as Carlos says, if you've popped a 100n in place of a 100p in a low pass filter, designed to block ultra sonic hash from reaching the amp, then it could have happened. If all you've replaced are electrolytics then it's doubtful that this would have happened, also the cap type is unlikely to create this kind of effect unless you used a faulty part.
Perhaps you're just imagining things, the A1 to my ears was always very smooth and round around the edges, certainly not an overly bright amp by any means. The tl072 based opamp in the preamp can easily be bettered by a suitable opa134, so you might want to give that ago, as even objectively the 72 is a rather poor performer, but it does depend on the application.
Do be careful though if you choose to go the measurement route, the A1 doesn't have any protection to keep it alive if the output get shorted to ground, so make sure the amplifier is off when making any changes to the connections. As you've experienced, those output transistors are a pain to replace, you don't want to have to do it again.
What the hell are you screamin' for? Every five minutes there's a bomb or somethin'! I'm leavin! bzzzz! Now with website! www.5een.co.uk under construction.
Musical fidelity A1 all recapped but sounds muffledHide this!Advertise here!
anyone know the musical fidelity a1 -x amplifier tube shop Solid State 11 26th October 2015 12:38 PM
Musical fidelity A1-X Bonsai Solid State 15 2nd November 2013 12:16 AM
Musical Fidelity X-A1 Upgrade ChrisR1983 Solid State 1 28th August 2009 12:16 PM
Musical Fidelity A1 Heatsink Assesears Everything Else 5 17th February 2004 08:45 AM
JLH Or Musical Fidelity A1? Jay Solid State 1 16th September 2003 01:40 PM
