Hello All,
I'm new on this forum and is for me a pleasure to partecipate at this community. I need some help for understand if my power amp is good or have few problem: My amp when is cold give around +60mV of dc offset on output, then after around 20-30minutes, when heatsink reach 27-30°C the dc offset drop down until 5-10mV,when is very hot less than 5mV What do you think about this? Can someone let me know if my amp is ok or if there's some problem? Many thanks for help
#2 |
After warm up, 5 to 10mv is good. I would not worry about it.
#3 |
Nothing wrong with that.
#4 |
behavior like that will mean one amplifier that is depending very much on the hfe of the transistors that form the circuit .
most of elektor amplifiers are like that also will mean that it could be one amplifier with plenty of output transistors but with marginal or low bias so its expected that before amplifier equalize to an ""operating""temperature both bias and offset values will not be correct . If the amplifier hasn't plenty of outputs it could be a minor error in the thermal design Would be nice to know what are we talking about ... Kind regards sakis
SERVICE ΕΝΙΣΧΥΤΩΝ ΚΑΙ ΙΑΠΩΝΙΚΩΝ ΜΗΧΑΝΗΜΑΤΩΝ ΗΧΟΥ www.eastelectronics.gr |
#5 | |
Sakis, if i try to increase a little bit the bias curruent (F.E.from 12 to 13mV) the temperature of heatsink increase exponentially and i don't know if there's some risk to burn my PA |
#6 |
Altering the bias current will not affect the DC offset. They are two different things.
I doubt bias would be stable to 1 mv anyway. Measuring with the amp hot and then cold will give different results. Always use the manufacturers setup procedure and values as a starting point.
------------------------------------------------------- A simulation free zone. Design it, build it, test it. |
#7 |
Yeah that is true..another strangers is if i measure the bias on mosfet N (4in parallel) there's always some difference of bias current..12,18,22,16mV...and the same for P rail
#8 |
or does that difference reflect the 5% tolerance of the source resistors used in the build.
You cannot rely on 5% tolerance resistors to give better than a 10% spread of source currents. |
#9 |
#10 |
| DC offset | emmi | Solid State | 3 | 9th June 2012 04:08 PM |
| DC offset | GregH2 | Solid State | 35 | 30th March 2012 03:04 AM |
| DH-220 Clone (SMART TA-242) can't adjust DC offset using offset bias pot? | beady | Solid State | 6 | 17th March 2011 10:53 AM |
| What is DC offset? | spooney | Car Audio | 13 | 2nd March 2008 10:35 PM |
| DC offset need help again :-( | djdamix | Solid State | 13 | 26th October 2004 08:38 AM |
