ESD Bench mat. How much coverage?? - diyAudio
Old 12th September 2012, 07:59 AM   #1
Default ESD Bench mat. How much coverage??
Hi.
I have just finished building a new workbench. The top measuring 2000mm x 900mm.
I would like to purchase some ESD rubber matting for the work top. My question is, how much covering will be enough? These mats are expensive here in S. Africa. Is it a good thing to cover the whole top, or more practical to do only a section??
Old 12th September 2012, 08:52 AM   #2
sofaspud's Avatar
You only need a section large enough to fit the circuit board being worked on. Before the static-sensitive components are stuffed on the board, they should be kept in conductive foam, wrapped with foil, etc.
It is error only, and not truth, that shrinks from enquiry. - Thomas Paine
Old 12th September 2012, 01:46 PM   #3
DUG is offline DUG  Canada
Don't forget the wrist strap and ESD soldering iron.
Doug We are all learning...we can all help
"You can't stop the signal, Mal. Everything goes somewhere..."
Non ESD-Safe Soldering iron to ESD-Safe tronxkid Equipment & Tools 9 24th October 2011 01:00 AM
Even bass coverage in bassment xplod1236 Subwoofers 19 20th December 2007 11:59 AM
PCM1702 sensitive to ESD? klitgt Digital Source 11 14th February 2006 06:22 AM
Hakko 936 - ESD safe vs. non-ESD safe KT Parts 2 20th June 2004 04:58 AM
Copyright 1999-2017 diyAudio
