Studiomaster 1500E HELP? - diyAudio
Old 10th September 2012, 08:58 PM   #1
Default Studiomaster 1500E HELP?
Hi all,
My fuses on the output side keep blowing any ideas?
Old 11th September 2012, 01:09 AM   #2
Enzo is offline Enzo  United States
I don't know the unit, so...
Power supply fuses? Or speaker fuses?
If speaker fuses, then likley you have DC on the output, start by looking for bad output transistors. If the amp will hold a fuse without a speaker load, then you can find out why the DC is there.
If power supply fuses to the channel blow, again start with looking for shorted output transistors, or posibly an open in the bias circuit.
Old 11th September 2012, 05:15 AM   #3
The 1500e does not use speaker fuses or output relays. it uses quite a sohphisticated protection circuit that includes a crowbar circuit to protect speakers in case of a large dc offset. if the crowbar is triggered it will short out the psu rails to open the fuses. As Enzo says there is also a possibilty that the output transistors could be shorted/Faulty. Please take note that this amplifier uses fairly high supply rails and can deliver a large amount of current please take caution when working on this amplifier..
best regards Mark
Old 14th September 2012, 09:11 PM   #4
Thanks for info. Please note when amp was powered up fuses went this happened without any load on amp.
studiomaster vision 8 smiglet Solid State 2 30th April 2014 10:14 PM
studiomaster vision8 burbeck Solid State 25 15th January 2013 09:18 AM
Studiomaster 16-4 suchenderxxx Analog Line Level 11 11th July 2012 12:11 AM
Can Someone help (Studiomaster mod) kinguk Analog Line Level 3 20th December 2009 04:44 PM
Studiomaster 400c Pbassred Solid State 3 25th October 2007 07:53 AM
Copyright 1999-2017 diyAudio
