help with mosfet power amp output impedance calculation - diyAudio
Old 10th September 2012, 09:35 AM   #1
The Dastardly Dad of Three
Default help with mosfet power amp output impedance calculation
Hi there,
Am messing about with the F6 concept amp but have a more fundamental question that I haven't been able to understand - how does one solve for the output impedance for a common source power fet output stage? Take the example below - wikipedia says that the output impedance = RL but it most certainly is not (in quasi complementary, llquam found 44R open loop, I found similar). The online references I can find jump into small signal analysis and I get lost pretty quickly
Can anyone suggest where I might look or an equation to try and get close to what is measured empirically ? Assume Gm approx 8S ...
many thanks in advance! Cheers,
Old 10th September 2012, 09:39 AM   #2
I can't help but I am a beginner also trying to determine output impedence of my ancient mosfet amp (500w per channel) so that I can build appropriate speakers ...
Old 10th September 2012, 09:59 AM   #3
Measuring it should not be too difficult.... I use this method:
Measure voltage across a dummy load, lets assume this is V1 and the load resistance is R1.
Change the dummy load to a lower value and measure the voltage across the load and resistance of the load, lets assume this is now V2 and R2.
Output impedance = [(V2/R2) - (V1/R1)] / (V1-V2)
Needless to say, we leave the input voltage of the signal to the amp untouched so that they are the same for both measurements. I think the standard is to measure it with a sinewave signal of 50Hz or 1Khz but I'm not sure about this point... perhaps the more experienced on the list will be able to tell.
My problem is correlating the measurement to a computed estimate, i can't figure out how to calc an even remotely close estimate to what I measure.....
Old 10th September 2012, 10:05 AM   #4
but under what conditions do the measurements hold true?
If the ampliifier sees a different drain load then the amplifier will behave differently.
eg, Drain load = 2k and output load = 100k. the transistor sees the total load as 1k96
You can now find the amlpifying abilities of the transistor.
Change the output load to 200k and to 50k and you will find that the transistor behaves as much the same as an amplifier.
Now attach an output load of 1k.
You have completely changed what the transistor sees as a drain load.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 10th September 2012, 11:18 AM   #5
Yes - I should have suggested that R2 and R1 bear some resemblance to actual loads eg 8R and 4R ....
Old 10th September 2012, 11:51 AM   #6
So for load of 4ohms or 8ohms one would expect the Drain load to be less than 10% of external load, so that you don't ruin the amplifying ability of the transistor.
But you can't use a Drain load of 0r4 nor 0r8 in common Source mode.
Do you see why the apparent output impedance is being measured wrongly? You are attaching an external load that ruins the transistors ability to amplify.
You must add a buffer between your 4ohms or 8ohms external load and the Drain load, to allow the amplifier to work properly.
regards Andrew T.
calculation of output power?.. clovi_kate Solid State 28 16th March 2016 02:31 PM
Power amp output - BJT or MosFET? Bill Fitzpatrick Solid State 21 9th February 2015 07:40 PM
Output impedance of various MOSFET followers at low (<10mA) currents bigwill Tubes / Valves 18 13th October 2009 07:21 PM
Possible to design a high-power class D amp with a low output impedance? 454Casull Class D 2 23rd February 2009 08:33 PM
Calculation of RMS power output? protos Solid State 47 1st February 2003 09:11 AM
Copyright 1999-2017 diyAudio
