ultra hifi amp new
ultra hifi amp new
Old 9th September 2012, 08:40 PM   #1
400kg is offline 400kg  Turkey
Send a message via MSN to 400kg
Default ultra hifi amp new
šok temiz ses . tam simetrik yapı
Old 9th September 2012, 08:46 PM   #2
If someone from PCB designers lurking this forum has extra time to design PCB, this can become serious competitor for the DIY-ers best option of choice to built their first (and maybe the last) solid state amplifier.
Old 10th September 2012, 01:32 AM   #3
Struth is offline Struth  Canada
Hi Guys
Did you measure the THD and bandwidth or are these "optimistic guesses" based on similar circuits? Is the 100db S/N based on full output?
Personally I would change the Miller compensation to a single cap going from the top of the bias reg filter cap to the feedback node - maybe with a small R in series. This separates slew rate from bandwidth and allows a bit more feedback to reduce high-frequency distortion. It made sense to me back in 1982 or so when I saw Cordell's article about his high-performance mosfet amp in the Siliconix app book.
The BD139/140 are only rated for 80V, so won't survive in your +/-60V circuit. Many amps use the MJE340/350 (300V) pairs. I like the 2SC4739/2SA1837 pair (230V).
I built an amp similar to this in 1980. One issue is the gate turn-off speed is slow and causes a lot of high-freq distortion. A possible fix is to add current sources where the 330R gate-leaks are.
You don't need back-to-back zeners for the mosfets as there is no reversing voltage. Single polarity protection is ample.
One last thing: I always add a 1k or so from the output node to ground. This provides a DC path to ground for leakage currents and gives the output stage a ground reference, making the DC centering task easier for the front-end.
Have fun
ultra hifi amp newHide this!Advertise here!
KTA-HiFi ST-70 pcb or marantz 8b. HiFi build iglehart332 Tubes / Valves 18 18th March 2011 02:19 AM
Ultra AMP Havenwood Solid State 13 29th January 2009 01:26 AM
The "Freebird" ultra clean ultra simple preamp design Russ White Chip Amps 87 11th August 2008 09:28 AM
Seeking ultra, ultra mini 1uF elec cap Triophile Parts 11 6th April 2005 11:17 PM
FS Rotel THX Ultra proc & amp googleguy Swap Meet 0 24th August 2004 10:30 PM
