1DIFFQC amplifier
1DIFFQC amplifier
Old 17th September 2012, 09:08 PM   #41
currentflow is offline currentflow  United Kingdom
Hi Harrison,
Would you envisage a thermal instability issue if I mounted the output transistors and the Vbe multiplier only on the main heatsink? The drivers would have separate heatsinks. Finally, what is the maximum (safe) supply voltage that can be applied please?
Thanks in advance.
currentflow
Old 17th September 2012, 09:14 PM   #42
OnAudio is offline OnAudio
OnAudio's Avatar
Thanks Currentflow. There is a sneaky advantage of having the drivers on main heat sink and that is higher hfe. However if they are mounted on separate heat sink there is better thermal stability. +-50 unless you change the vas area transistors and out put transistors. Its a dissipation issue ( you could even give them baby heat sinks )and max break down voltage issue.
onaudio.herokuapp.com
Old 17th September 2012, 11:51 PM   #43
Kindhornman is offline Kindhornman  United States
Kindhornman's Avatar
Harrison,
Warp Drive May Be More Feasible Than Thought, Scientists Say,
I knew those Dylithium crystals would come in handy when they are off back-order.....
Old 18th September 2012, 03:16 AM   #44
OnAudio's Avatar
Thanks Kindhornman
Old 18th September 2012, 03:28 AM   #45
Still trying to come up with a part number for a nice fuse holder. All I keep finding are simple fuse holder ends that mount on the board but they just look cheap. I would much rather have them in a holder with a base to it. I know that someone posted a picture of their amp that was the first one partially assembled with fuse holders but I am not finding that thread right now to ask that person what they were. No reason to make this thing look cheap.
Old 18th September 2012, 03:57 AM   #46
Found a nice fuse holder. Mouser PN 534-4527 and cover PN 534-4527C Made by Keystone
Old 18th September 2012, 04:03 AM   #47
evette is offline evette  Canada
Send a message via Yahoo to evette
Mr.kindhornman If you like you can pm me with your address and I,ll send you some. Regards Evette
Old 18th September 2012, 04:06 AM   #48
How dare you make fun of america,s sex queen. LOL Evette
Old 18th September 2012, 04:10 AM   #49
Mr.Harrison I would be more than glad to built you friend an amp,,I,m very sorry to hear that he can,t do it himself. But remember I,m very slow I canm only use 1 hand So if your friend can wait a little I,ll gladly do it. Evette
Old 18th September 2012, 04:13 AM   #50
The heat from the drivers with this amp is really a non issue. Evette
1DIFFQC amplifierHide this!Advertise here!
Questions about how to decrease the PASS A-40 amplifier into a class AB amplifier. novtango Pass Labs 4 14th February 2018 05:11 PM
Hypex SMPS400 + 2x UCD180 wiring (DC error, Auto Amplifier Enable, Amplifier Standby) maxw Class D 48 26th May 2017 06:47 PM
Burning Amplifier 2012 Nominee 1DIFFQC OnAudio Pass Labs 9 31st October 2012 01:25 PM
An amplifier to take to University - A small low power integrated amplifier monty78pig Solid State 33 31st August 2012 06:00 AM
Wanted: DIY amplifier builder with experience. I need a 0.7 ohm stable amplifier Audiophilenoob Swap Meet 34 16th May 2005 11:58 PM
