Old 5th November 2012, 09:27 PM   #111
bobfig is offline bobfig  United States
Send a message via Yahoo to bobfig
yah i say that attachment from the link earlier you posted. i don't comprehend what its saying. if i had it in a scamatic style drawing i could maybe understand.
Old 6th November 2012, 03:15 AM   #112
Hi Bob,
Went window shopping for you. You could bring down the costs by using these options.
Capacitors
You may parallel as you wish
SLPX682M063E7P3 Cornell Dubilier Electronics (CDE) | 338-1651-ND | DigiKey
ECO-S1KP472CA Panasonic Electronic Components | P7372-ND | DigiKey
Transformers
1 * 800VA for stereo Antek - AN-8230
or
2 * 400VA for stereo Antek - AN-4232
www.harrisonaudiolabs.com
Old 6th November 2012, 03:29 AM   #113
Its the regular power supply represented as functional blocks .
Old 6th November 2012, 06:15 AM   #114
Originally Posted by OnAudio View Post
Hi Bob,
Capacitors
Transformers
or
thanks for the help
wow so this is going to need 2 transformers and ima have to get 2 of those blue power supply boards? this thing seems like it dose swing some power. i wasn't expecting it to be so much tho. lol
so you're accepting this layout x2 with duel 400va transformers?
also i notice that on the board there is coil 1 and coil 2 whats the measurement on that?
Old 6th November 2012, 06:13 PM   #115
Hi Bob,
Cooking an answer
Old 6th November 2012, 06:16 PM   #116
i hope its yummy
Old 6th November 2012, 06:28 PM   #117
thanks for the help
The on amp board 33u/47u capacitors are for the amp board and are part of the amp BOM. For PSU board you could parallel 3*2 = 6 : 6800 caps on the PSU board . Remember to use a line filter on the incoming a/c power line.
You have various options of transformers (assuming a stereo setup and operation with either 8 ohm or 4 ohm speakers (nominal 4 ohm, 2 ohm ), total stereo either 2 ohm or 1 ohm load on transformer). That brings recommended cap size to 20,000u per rail(total 40,000uf) for stereo.
Transformer rating
300VA*2, 400VA*2, 600VA*1, 800VA*1
Thats the output inductor L1 connection. Its 1uH . The schematic is here http://www.harrisonaudiolabs.com/Amp...QC/1DIFFQC.pdf
Old 6th November 2012, 08:58 PM   #118
i hope its yummy
Looking forward to review your choice again
Old 6th November 2012, 09:05 PM   #119
hmm ok now i just need to slowly start buying parts as this is going to get expensive.
Old 6th November 2012, 09:21 PM   #120
You could set a budget limit (just like big firms) and work around that ie , 2200u caps * 8 * $2 = $16
Burning Amplifier 2012 Nominee 1DIFFQC OnAudio Pass Labs 9 31st October 2012 01:25 PM
An amplifier to take to University - A small low power integrated amplifier monty78pig Solid State 33 31st August 2012 06:00 AM
Hypex SMPS400 + 2x UCD180 wiring (DC error, Auto Amplifier Enable, Amplifier Standby) maxw Class D 10 29th August 2012 02:23 AM
Wanted: DIY amplifier builder with experience. I need a 0.7 ohm stable amplifier Audiophilenoob Swap Meet 34 16th May 2005 11:58 PM
Questions about how to decrease the PASS A-40 amplifier into a class AB amplifier. novtango Pass Labs 2 21st October 2002 01:50 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
