what factors will give iron fist bass? - Page 2 - diyAudio
Old 9th September 2012, 02:16 AM   #11
expert in tautology
bear's Avatar
Aside from what Frank said - Damping Factor.
Try some Crown MacroTech amps... the bigger ones have excessive power and very high DF. They put a second FB loop in the the "MacroReference" for even higher DF, you could probably mod a standard MacroTech and add the second loop...
Of course, a very high DF will *reduce* the apparent bass extension on a speaker with a relatively low Qt...
_-_-bear
PS. why Frank is correct: the leading edge of a bass hit is high slope. High slope is routed to the HF section of a speaker - of course the fundamental still goes to the woofer... think about the timing relationship that is required to reconstruct the original? This is also a factor in "realism".
_-_-bear
http://www.bearlabs.com -- Btw, I don't actually know anything, FYI -- every once in a while I say something that makes sense... ]
Old 9th September 2012, 03:44 AM   #12
I have a pair of 10 inch vifa Premium line 8 ohms woofers.
I felt that good drivers makes all the difference but good amps are definitely required.
I do accept that tweeters are very important in the aspect I have again decent tweeters scanspeak 9300 which gives the illusion of better bass. I have checked that but getting the damping factor I think like not less than 800 is my min requirement.
Im considering paralleling many psu caps smaller values like 1000uf x 20 per rail to decrease the discharge times from the caps and hence could increase damping factor.
Second feedback loop: how do I do that and what values that I need to consider for that?
I am very interested to mod the above module since feedback is just one resistor. May be for double feedback could be two.
I want to first test the quality of the above module but im worried about tight bass..
what is the psu recommendation...
Old 9th September 2012, 03:48 AM   #13
Pano is offline Pano  United States
Pano's Avatar
OK, for many of us a 10" is a midrange driver. Vifa makes nice drivers, no mistake, but a 10" woofer and iron fist bass just don't go together in my mind. Maybe I'm wrong?
Old 9th September 2012, 04:17 AM   #14
BudP is offline BudP  United States
BudP's Avatar
Here is what will give you iron fisted bass. This will rival a thunderstorm outside your home for spl, transients and terror factor. Each sub box paired with a couple of Eminenece Beta 8 mid bass drivers, for the rest of the iron bass experience, will so satisfy your need that it will be decades before you out grow a pair. The more power you throw at these pro audio 15 inch woofers, the more power will shake your house, the whole thing, including window glass. They don't take up much room either. 20 Hz with astounding authority, from our benevolent friend Gary Pimm.
Bud
"You and I and every other thing are a dependent arising, empty of any inherent reality" Tsong Ko Pa
Old 9th September 2012, 04:38 AM   #15
Pano's Avatar
I've heard those and they rock! Thanks for the pics, Bud.
Old 9th September 2012, 04:43 AM   #16
CBS240 is offline CBS240  United States
CBS240's Avatar
_-_-bear
Good damping is essential to better control of the machanical motion of the speaker, high frequency damping is as well. This is where local high bandwidth error correction comes into play. Once you go EC, you won't go back.
All the trouble I've ever been in started out as fun......
Old 9th September 2012, 04:44 AM   #17
TerryO is offline TerryO  United States
TerryO's Avatar
What are you planning to use for the "Iron Fist in a Velvet Glove" treble?
"If you have to ask why, then you're probably on the right track."
quote from Terry Olson's DIYaudio Forum application
Old 9th September 2012, 04:51 AM   #18
frugal-phile(tm)
planet10's Avatar
Appropriate damping for the speaker being driven. An amplifier can have too much damping and you end up with lean bass.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 9th September 2012, 05:37 AM   #19
BudP's Avatar
Gary Pimm uses a Crown DC 300 (?) as I remember. So, whatever the damping factor of one of those hoary old things is will be just fine with the good lords own thunderboxes. Seriously, Gary said the build was very straight forward and the blue stuff is chopped blue jeans matted into wall insulation for homes. I am sure I can come up with the woofer models if this get's you excited.
Bud
Old 9th September 2012, 07:01 AM   #20
frugal-phile(tm)
planet10's Avatar
Originally Posted by BudP View Post
... and the blue stuff is chopped blue jeans matted into wall insulation for homes.
Bonded Logic UltraTouch
dave
Second approach to maximizing bass output in Iron Lawbreaker thoriated Multi-Way 17 17th October 2014 11:47 PM
Rock and Roll speakers, is a Chebyshev bass XO going to give more "Kick"?? Moondog55 Multi-Way 11 18th July 2012 05:34 AM
My fist Pass Amp Nikon1975 Pass Labs 9 9th November 2010 07:49 PM
Factors affecting speaker precision? keantoken Multi-Way 27 2nd September 2010 06:34 PM
OPT Quality Factors? weinstro Tubes / Valves 1 3rd November 2007 06:20 AM
Copyright 1999-2017 diyAudio
