yamaha m60 power supply issues
Old 7th September 2012, 06:20 AM   #1
nanooker is offline nanooker
Question yamaha m60 power supply issues
Hi folks, first time posting having an issue with a repair on the way to an upgrade on a yamaha m-60 amp. My power supply tansformer is reading low about 5v on the LB's and 12v down on the HB. Suggestions as to something other than replace the pws. The owner that i rescued this amp from started the carnage by installing the 50v ripple caps backward. I have since replaced 4 output transistors, 3 input transistors, some s1115', 2240's, 5 caps 4 resistors, zeners and signal diodes. and all four ripple caps with new panasonics. I have no Leds or haven't been able to engage the y101 relay. I was unaware incorrectly installing the ripple caps could take out a power supply. Out of circuit it is low on everything. In circuitit is not even close to the schematics values. If some is knowledgeable about the yamahas i waould surely appreciate some guidance. I was given with the amp a bag of parts within was all the other caps all elna's and nichicons along with most of the diodes and transistors. I have reflowed the board and pulled each piece and verufied out of circuit. But this powers supply in circuit behaves as if there is a dead short. I have found no other blown parts. I'm a novice and have recapped and modded two other yamahas and have a basic understanding of electronics. Stumped in Albuquerque, Nanooker
yamaha m60 power supply issuesHide this!Advertise here!
Yamaha RX-730 power issues Smoothjazz Solid State 6 21st November 2012 04:22 AM
FS: Yamaha M60 Power Amplifier- Partly Rebuilt - $99 Unimog Swap Meet 5 12th February 2012 11:19 PM
Yamaha M60 modifications? Unimog Solid State 4 13th December 2011 02:55 AM
more help, power supply issues theChris Solid State 15 11th April 2003 06:54 PM
help on power supply issues and more! mwmitchell Tubes / Valves 2 16th August 2002 01:35 AM
