How to determine max RMS input for given (commercial) Amp? - diyAudio
Old 5th September 2012, 11:50 AM   #1
Default How to determine max RMS input for given (commercial) Amp?
Hi All,
I would like to determine the max RMS input voltage for a Rotel RMB-100 Amp.
I do have the schematics and I guess that this is determined by the Input circuitry.
Could u kindly let me know what to look out for (like max. voltage smwing on Opamp with a given power supply voltage, etc.)?
Is this the way to go ?
Max
Old 5th September 2012, 12:57 PM   #2
From this site archive, the input sensitivity is 1.0V for full rated output, as HT equipment should be for compatibility.
Ian
Old 5th September 2012, 01:20 PM   #3
You have now started 3 identical threads, Coolnose. It's hard to make sense here but this is a monobloc amplifier, without gain controls, I think.
Ian
Old 5th September 2012, 01:31 PM   #4
amptech is offline amptech  Scotland
Send a message via MSN to amptech
As Iain, says 1volt for a given o/p and on some amps it's 750mv
How to build a circuit to determine the input sampling rate? Kuro Digital Source 47 12th December 2011 01:31 PM
How to determine power input with shaped toneburst? cuibono Multi-Way 0 30th July 2009 03:13 AM
Speaker wattage[rms] versus amp wattage[rms] Bull Multi-Way 5 9th November 2002 05:55 AM
does someone know the max rms power rating of the Blueprint 1503 driver? pkgum Multi-Way 3 9th December 2001 01:50 PM
Copyright 1999-2017 diyAudio
