Combining 3 Band Pass Filters
Old 4th September 2012, 04:17 PM   #1
JoshwaBurke is offline JoshwaBurke
Exclamation Combining 3 Band Pass Filters
So I've been building an equalizer for an amp I built.
I'm now working on a 3 band equalizer to use with the amp for a class. I could use some help with the design. Trying to keep it simple but I'm getting a little frustrated
• The Equalizer Pedal will be powered using a 9V battery
• A push button will turn the foot pedal on and off
• A minimum 3-band equalizer will be designed
• Low (Bass) center frequency band: 78Hz (5% tolerance)
• Middle center frequency band: 1.15kHz (2% tolerance)
• High (Treble) center frequency band: 7.8kHz (2% tolerance)
• At least +/- 15dB per band
Could someone help me out with my circuit. I'm not sure how to combine the filters
Any other comments or suggestions would be very helpful. Trying to get a working circuit and get a working model on my breadboard.
Combining 3 Band Pass FiltersHide this!Advertise here!
DIY Low Pass and Mid/High Pass (Bass Blocking) Filters runslikealpaca Everything Else 1 19th June 2009 10:59 PM
2 Art 351 EQ (31 band w/ subsonic filters) cdoggy81 Swap Meet 2 7th October 2008 09:59 PM
A question on low pass filters Vaughan Subwoofers 15 10th October 2007 04:23 AM
High-Pass Filters? pixie Multi-Way 4 17th September 2006 03:02 PM
Maxim high pass filters Optical Solid State 5 20th November 2002 10:26 PM
