#261 | |
I had made the effort to provide two sims of the same amp, VFB vs CFB. You can't deny my effort on that. Sims are not a kind of metric ? For the other part of your answer, there is a funny thread, in this forum about sound of cables. I can listen differences of sound with different loudspeakers cable's capacitance on long distances, (special when they make the amp oscillate), with non linear Z loudspeakers and diameters, no more. And my answer about cables is this citation: "I tend to prefer those witch conduct electricity". Read my signature, to know my position. Last edited by Esperado; 2nd November 2012 at 08:52 PM. |
#262 | |
The measurement shows the gain and phase of the Ltp ..
"please try to listen to some music through the amplifier instead. Life is so short ..." |
#263 | |
SCIENTELEC Haute Fidélité française and the measurements he made (remember 1970 !) RightMark Audio Analyzer test : Mach_A50S The" audiophile" word was not even invented. And, sorry, but, yes we used to listen to our work (not the way you describe, but with criticism) as much as we where making measurements at each step, because there is no other way to work for audio in a research and development office. We where the first, i believe to provide a 24pos rotator with constant impedance to replace potentiometers and a physiological circuit, following exactly the Fletcher and Mudson curves. Last edited by Esperado; 3rd November 2012 at 05:17 AM. |
#264 | |
With blind test, I will set up a system that will display the strengths of the CFB. And blind test, especially by experts, tho not scientific, is the best way to decide which one is best. Because there is no scientific approach, even if you want to pretend that there is one. I trust my honesty. If I found the VFB sound better I will right away throw away my CFB. I have no special relationship with CFB anyway. And if everyone is as honest, no need a blind test. Just show two amps and we will build both of them and give our reports. |
#265 | |
ADD: The Stochino is the best amp I have built with hexfet at class-B. It's just like the basic of latfet-SSA as built by Nico and Shaan, but the latfet is replaced with HEXFET plus a (5401/5551) driver. I was trying to help others with "cheap" SSA/CFB (using cheap hexfet, and no need big heatsink and transformer), but the result was not good. Hexfets are for class-A I guess. Last edited by Jay; 3rd November 2012 at 08:03 AM. |
#266 | |
That configuration of the single transistor used as a subtractor was therefore the most straightforward, economical and effective, and it was used in ~75% of amplifiers designed at that time. First, three examples using Ge transistors, from Philips, Siemens and Thomson. Then, some later examples based on silicon. But there was no awareness or intent from the designers to create CFB, quite the opposite in fact: this effect was seen as nuisance, as it spent uselessly part of the loop gain. There were therefore "clever" attempts to circumvent the effect, without using a disproportionately large feedback electrolytic (necessitated by the low impedance of the FB network). The next pic shows an example of such a smart scheme, where the speaker is part of the impedance of the FB divider. Finally, a curiosity: an amplifier duplicating the tube OTL, with a composite MOS/bjt IC as input, also with CFB. Now, you could say that CFB already existed at the time, but unbeknown of the designers, "à l'insu de leur plein gré", just like Mr Jourdain had been speaking prose all his life without knowing it.
#267 |
Two more examples from Philips:
#268 |
Jay,
I never claimed that Pioneer/Tannoy pair is state of the art. Like I said it is for low power reproduction from TV/FM tuner, it is not my main music reproduction system. Although budget priced, Pioneer amp is excellent sounding and the circuit is very good. It is not run of the mill Japanese product but the work of some clever and very competent Japanese engineer. I know Stochino circuit and I do not think that building it would bring any real improvement in sound quality over Pioneer circuit. I do not think that Japanese engineers are less competent than any other engineers just because they remain nameless and because they work for big companies. In fact, just the opposite may be the case. |
#269 | |
I'm impressed with your schematic library ! We had no time, on our side, to look at other's company work. some in the datasheets, yes... Note: Our amp had something a little special at this time, using the first planar power transistors for more speed (BDY56, if i remember well)... |
#270 | |
![]() I have the french book wich you are displaying schematics from. Just remember the whole bunch of theses early unwillingly CFB designed amps , and the remaining impression after all this time is that , although a majority did more or less work , they were also as a majority of poor quality.. ![]() The generalisation of the LIN was a relief and we could then talk of hifi amplifiers and get rid of thoses designs where you could often improve a parameter only by degrading another one.... |
| Superior Instruments tv11 restore question? | djmike | Tubes / Valves | 1 | 5th January 2013 08:02 AM |
| Is there a superior NPN TO3? | grhughes | Parts | 2 | 28th September 2012 12:55 PM |
| Why are mesh plates supposed to be superior? | kavermei | Tubes / Valves | 1 | 29th August 2009 05:04 PM |
| heco superior presto 750 | mschwilson | Multi-Way | 0 | 6th December 2006 06:34 PM |
| Superior Electric Variable Transformer | CCOZGO40 | Swap Meet | 1 | 28th October 2002 02:41 PM |
