Is the CFB topology superior, and why?
Old 22nd October 2012, 08:09 PM   #211
Esperado is offline Esperado  France
Banned
Joking...Impedances are up to you...
Old 22nd October 2012, 09:15 PM   #212
wahab is offline wahab  Algeria
Originally Posted by Esperado View Post
You are right. Just increase those to 1.4K to push the driver quiescent to the same value than original and have a fair comparison ?
Too, i was wrong, telling that the Power Mosfets where IR, they where original Hitachi, i think. Time is so far away, when i constructed this amp and my memory burn-out with time to lower value.
A distorsion test would be interesting , just use whatever
soundcard you have , it will be enough up to a few Khz.
As spectral analyzer Visual Analyzer or RMAA should do it perfectly.
Old 22nd October 2012, 09:16 PM   #213
magnoman is offline magnoman  United States
Christophe
Thanks wasnt sure.
I was just trying to show what is needed to have the same loop gain between the ltp and complimentary emitted coupled pairs.
This later cfa topology does allow one to theorectically zero out its distortion with emitter resistors to the feedback point.
-Antonio
Old 22nd October 2012, 10:05 PM   #214
Banned
I believe in my old LEA. The original amp showed something like 0.008/9 % reduced by something i evaluate as a 10 factor with current feedback (needle was moving too much with the noise to can measure anything).
Old 22nd October 2012, 10:24 PM   #215
Such estimation cant be right as it involves one order of magnitude
better linearity , yet there is still two stages and the original Crescendo
already almost maxed out the THD numbers that are possible for two
stage topologies.
So either your amp has 20db higher OLG , wich is not the case
or the components did magicaly yield ten times better
built in linearity....
Old 22nd October 2012, 10:40 PM   #216
Banned
Wahab, as i said, it was too low to measure. The only thing i'm sure about is that distortion was decreased significantly.. I tribute-it to the speed improvement.
Old 31st October 2012, 02:33 PM   #217
Elvee is offline Elvee  Belgium
Elvee's Avatar
To close the subject, here is a final example showing how misleading preconceptions can be.
This output stage has performances that most aficionados would think as typical of CFB: sub-ppm linearity, output impedance in the microohm range, etc
Yet, it is a pure VFB, but more than that it is an absolute extremist of its kind: the feedback is 100%, and pure voltage mode, and the input by contrast is almost in current mode (sort of). In fact, the exact opposite of CFB.
Think about it...
. .Circlophone your life !!!! . .
♫♪ My little cheap Circlophoneİ ♫♪
Old 31st October 2012, 05:05 PM   #218
Banned
Replace Q8/Q10 by low Z resistances, and common base by common emitter for the input stage, what is-it ?
Old 31st October 2012, 05:13 PM   #219
dadod is offline dadod  Croatia
dadod's Avatar
Non switching!
Haw about the bias, is it something close to the Edmond non switching auto bias OPS?
Could you give some more information?
dado
Old 31st October 2012, 07:02 PM   #220
Elvee's Avatar
Apart from mundane biasing details, there is one big problem there: it will become a schmitt trigger due to positive reaction.
I don't know, that is one of the many topologies I have investigated, I let you decide.
Maybe some day I'll publish a project
Is the CFB topology superior, and why?Hide this!Advertise here!
Superior Instruments tv11 restore question? djmike Tubes / Valves 2 2nd June 2013 06:09 AM
Is there a superior NPN TO3? grhughes Parts 2 28th September 2012 12:55 PM
Why are mesh plates supposed to be superior? kavermei Tubes / Valves 1 29th August 2009 05:04 PM
heco superior presto 750 mschwilson Multi-Way 0 6th December 2006 06:34 PM
Superior Electric Variable Transformer CCOZGO40 Swap Meet 1 28th October 2002 02:41 PM
Copyright ©1999-2017 diyAudio
