Old 28th August 2012, 12:57 PM   #1
Default how good is this amplifier?
Hi I've made my first MOSFET power amplifier, in the output stage I used the IRFP140 with IRFP 9140. The features are these:
rails +/- 21 V unregulated
output rms power 20W into 4ohm
thd 1 khz into 4 ohm 0.002%
thd 20khz no load 0.002%, 8 ohm 0.03%, 4 ohm 0,064%
signal to noise ratio 97 dB (1W into 4ohm), 108 dB (20W 4ohm)
thd is referred into pure resistive loads.
These are the values found using LTspice, I've built it and it sounds fine but i don't have the instruments to see the real performance.
So how is my amplifier? what do you think about it?
Old 28th August 2012, 03:54 PM   #2
juma is offline juma  Serbia
juma's Avatar
Originally Posted by davidel94 View Post
.... So how is my amplifier? what do you think about it?
I must admit that it has at least one very special feature - it's invisible. No schematic, no photos...
Old 28th August 2012, 04:58 PM   #3
moschfet's Avatar
These are the values found using LTspice..
Sorry, using LTspice to determine THD can give you a good direction for your development. But a realistic simulation of THD is almost impossible, you have to measure it later
Regards http://xipix.de/
Old 4th September 2012, 06:55 AM   #4
ok but assuming that these values are real how good is this amplifier?
Old 6th March 2013, 05:12 PM   #5
DF96 is offline DF96  England
You have made the same post to about 5 different threads. Are you trying for some sort of record?
Old 6th March 2013, 05:22 PM   #6
SY's Avatar
Actually, 12 different threads, I've deleted the duplicates. Davide, do not repeat the same post in multiple threads.
If there's a sucker born every minute, where do the rest of them come from?
Good amplifier jacobsetti Solid State 12 8th May 2012 03:08 PM
Good Subwoofer Amplifier broka Solid State 0 17th September 2006 06:25 AM
Is this amplifier good? destroyer X Solid State 11 4th May 2004 01:24 AM
Is this amplifier any good? (earthquake) thomas997 Solid State 2 4th March 2004 01:44 AM
Good A/B amplifier janey Solid State 4 6th December 2001 03:48 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
