School Project
School Project
Old 27th October 2003, 04:00 PM   #11
PRR is offline PRR  United States
PRR's Avatar
> since the negative terminal of U1A is a virtual ground
No it is not. Review your op-amp chapter. Virtual ground is the "-in" input on an inverter with grounded "+in" pin. In a follower, the "-in" pin is "virtual input" (it follows the "+in" pin). On an ideal amp, a cap from "-in" to "+in" does nothing at all. On a real amp, all that "virtual" stuff becomes untrue at 1MHz to 10MHz, where the amp's gain falls to nothing. So the effect of a cap here is not simple.
> should i be safe and move it to a real ground point?
Since Rod published it, I would use it as-is. With Rod's 100pFd cap across the pins. While you will get dozens of opinions "do this, it's better!", remember that Rod thought about the plan and built it. Surely most of those changes crossed his mind. Some of them are a matter of opinion. But the plan does not suck at all. And Rod and others have built it and seen it work. If you start tossing on every good idea you hear, it is easy to get to a place where it does not work.
School ProjectHide this!Advertise here!
School project wm-61a question paintrodsey Solid State 5 23rd March 2008 11:14 PM
Could use your help for school club project JZatopa Multi-Way 10 23rd February 2005 08:56 PM
School Project batkey Chip Amps 8 14th September 2004 02:09 PM
Need help with school project neonmoose Solid State 9 15th June 2004 08:44 PM
DAC for my cd-pro II school project BrianGT Digital Source 0 8th September 2003 01:45 AM
