Old 24th August 2012, 11:46 AM   #1
tiefbassuebertr's Avatar
Default unknown 6-pin Dual Transistors in "SC-88" outline for surface mounting
I am looking for types and datasheets from follow marking codes:
1) CA1MB (maybe CA1M8)
2) CU1MA
Who can help?
Old 27th August 2012, 06:55 AM   #2
No informations?
Old 27th August 2012, 10:21 AM   #3
alayn91 is offline alayn91  France
Hello,
In which hardware are they used ?
Regards.
Alain.
Old 10th September 2012, 10:15 AM   #4
Originally Posted by alayn91 View Post
Hello,
Regards.
Alain.
In follow digitale satellite receiver (DVB-S2):
"HD22" from "Nwe Line Electronics GmbH" (brand unknown, Made in China)
PCB designation: "STB-DECODER-14-V03"
The searched device (only CA1MB) is responsible for the LNB (LNC) voltage control for select the horizontal or vertical aera.
Similar switching regulators are follow:
http://www.ti.com/lit/ds/symlink/mc34063a.pdf
http://www.onsemi.com/pub_link/Colla...MC34063A-D.PDF
Google does not always search in the text of PDF files, otherwise one would find the appropriate type to this according SMD marking code.
Datasheet of Motorola's "SC10429" (SC 10429 Revox order code 50.05.0143) wanted tiefbassuebertr Analogue Source 3 2nd January 2013 08:20 AM
"Gold pin" Texas Instr. tripath TA2020 chips? charliefreak100 Class D 0 7th June 2011 10:30 PM
Dayton SD315-88 12" - DVC310-88 12" nixtux Subwoofers 3 2nd April 2010 05:49 PM
"Surface-mount HD DIP"?!? Help! slor Parts 2 21st April 2008 10:22 PM
Hi Res 550mm Fresnel Lens Set, 15"x11" First Surface Mirror, 6.3" IR/UV Filter, More! Ben_Tech Swap Meet 0 22nd September 2007 10:49 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
