Stereo width controll - diyAudio
Old 23rd August 2012, 05:31 PM   #1
geminni is offline geminni  Yugoslavia
Default Stereo width controll
I want to make stereo widener.
All I have found are schematics that remove center material. I want to add that to center material, not to lose it
I knwo that it can be done because I had an Aiwa cassete player that has one button to add stereo wide and it still sounds great, of course, it depends on music material.
I have been testing numerous combinations but can not find the right one
Old 23rd August 2012, 05:41 PM   #2
Banned
I think its pretty much the same effect those fake surround sound winamp plugins uses, adding phase shift and such.
Old 23rd August 2012, 07:22 PM   #3
I know for all those software thingies but I need hardware version
I have just seen schematics for Aiwa and they use some special circuit for what they call "Q sound". It is MM1434 ic. I'm thinking of making my version of "Q sound" with TL084 or similar.
Old 23rd August 2012, 07:44 PM   #4
djk is offline djk
djk's Avatar
Crown IC150
Apt preamp
Look at the schematics for both.
Candidates for the Darwin Award should not read this author.
Old 24th August 2012, 06:36 AM   #5
Even JLH had a version, it's published here in basic form by Paul Kemble as "image width module". Many magazines and manufacturers copied it back then. A Paul Kemble web page - John Linsley Hood preamp designs.
Ian
Old 24th August 2012, 07:05 AM   #6
abraxalito's Avatar
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
Send a message via MSN to abraxalito Send a message via Yahoo to abraxalito Send a message via Skype™ to abraxalito
One simple way to increase width is to make 'mid' and 'side' signals (M,S) then apply gain only to 'side' and re-combine into L and R again. Michael Gerzon played around with applying filtering to the 'side' signal I seem to recall, so you can try making the width frequency dependent.
Mid = 0.5(L+R) ; Side = 0.5(L-R)
A new scientific truth does not triumph by convincing its opponents ... but rather because its opponents eventually die, and a new generation grows up that is familiar with it. - Max Planck
Old 24th August 2012, 07:08 AM   #7
sofaspud's Avatar
Rod Elliott has a stereo width controller page here at his ESP site.
I'm also remembering Bob Pease discussing a similar function from a D. Hafler circuit as part of a "What's All This ____ Stuff Anyhow?" entry, but I can't seem to find it.
It is error only, and not truth, that shrinks from enquiry. - Thomas Paine
Old 24th August 2012, 07:36 AM   #8
picowallspeaker's Avatar
hardware version ?
Play with waveguides around the tweeters
Also midrange , if any , although it may be too difficult to make
a perfect constant directivity device .
Genelec 1034B is a Powerful Control Room Monitor System
Old 24th August 2012, 08:23 AM   #9
Basically you want to vary the differences between the channels. In TV we vary the chroma saturation by changing the amplitude of the chroma difference signals before re-matrixing back to RGB. You can do the same thing in audio by converting your L and R signals by summing to L+R and L-R. Varying the amplitude of L-R before re-matrixing back to L and R will accentuate or minimize the channel differences - expanding or contracting the sound field. It's just a few opamps and resistors and a pot for the L-R. What Abraxalito said.
I don't know specifically about the Aiwa but often times the stereo 'wide' only inverts the phase of one channel. Pretty hokey.
G
Old 24th August 2012, 08:40 PM   #10
In post #3 of this link is a circuit: http://www.pinkfishmedia.net/forum/s...d.php?t=108344
DEQ 2496 Remote Controll (under construction by myself) seoman Digital Line Level 139 15th March 2015 09:38 PM
gain controll kierrie22 Chip Amps 2 15th July 2008 06:54 AM
bass controll Chris8sirhC Subwoofers 1 27th August 2006 06:23 AM
volume controll in the feedback loop sss Solid State 24 11th July 2004 10:11 PM
Help! (with shunted volyme controll) hifi Solid State 6 28th January 2002 12:39 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
