Technics SU V505 problems
Old 21st August 2012, 06:14 PM   #1
dhbiker is offline dhbiker  Slovenia
Default Technics SU V505 problems
hi there
i have a small problem with this amplifier... to be exact with relay that does muting/output selection.. it works fine when i put a bit pressure on it... on power on it usually clicks several times instead of just once
i tried to look in service manual but under part name says only SSY-107
google also doesn't find anything useful
so i'm asking if anyone knows the substitution for this relay ?
thanks for your reply
Old 21st August 2012, 06:53 PM   #2
Mooly's Avatar
Are you 100% sure it is the relay at fault and not the drive to the relay that is responding to the pressure... in other words a poor joint in the amp somewhere and the relay is doing its job of protecting the speakers.
You need to measure the voltage across the relay coil to be sure it is present and the relay NOT engaging.
If the relay is faulty then there should be suitable replacements available. They usually follow a standard pinout. Coil voltage and its resistance would have to be matched and the rating of the contacts at least as high as the original.
Old 21st August 2012, 09:33 PM   #3
will check it out and report.. but since now there hasn't been any problems that's why i think its the relay
Old 22nd August 2012, 07:52 AM   #4
hi there
i'm pretty sure it's the relay... everything seems fine.. no poor joints
voltage across coils is present
and the relay also reacts to slightest touch from side.. like poke it a bit it works normally... poke it again it doesnt work anymore
Old 22nd August 2012, 07:58 AM   #5
Mooly's Avatar
From what you say that does point to the relay. If the voltage is present across the relay coil then it should work.
As to a replacement. You will have to determine if it is a standard pin out by comparing against other relays in the catalogues. It might help to see a picture of the underneath of it. If a pin compatible one can't be found then it's a simple matter to hard wire a different replacement in.
You need to measure the coil resistance (it says its a 24 volt coil on the relay) and choose one with similar or higher resistance. If it was much lower then it may not operate correctly or overload the relay driver transistor. Seeing the circuit of the relay driver would help in that case.
Old 22nd August 2012, 08:48 AM   #6
i'll take the bottom cover later today and take a pic.
Old 27th August 2012, 07:16 AM   #7
strangely it started to work properly .. probably because i was fiddling with muting/output selection circuit.. so this thread can be closed and deleted
Old 27th August 2012, 09:49 AM   #8
Mooly's Avatar
But will it last
Its well worth going over all the joints on the PCB to resolder them, particularly any parts that run hot.
Old 27th August 2012, 09:50 AM   #9
it lasts now for 2 days
will resolder then tnx for reccomendations
Old 29th August 2012, 06:15 AM   #10
well you were right about lasting part... they are back
so this is what my relay looks like from the bottom Click the image to open in full size.
also i'm going to put it in another case that is more opened to monitor the problems right away...
Technics SU V505 problemsHide this!Advertise here!
Technics SU-V7 Carlosraj Solid State 4 25th September 2011 10:57 PM
old technics SU-Z400 cutcat Swap Meet 1 27th December 2006 12:53 PM
Technics SU-V4X zoluic Parts 1 7th December 2006 05:29 AM
Technis SU-V505 B.I.G Solid State 2 1st June 2004 03:59 PM
Technics SU 8080 Squalo Solid State 2 2nd January 2003 04:38 PM
Copyright ©1999-2017 diyAudio
