I need a replacement for the 2SA968Y which compliments transistor 2SC2238Y, TO-66 body type. This transistor is used in the Harmon Kardon pm665 driver P.C. board PCB-3.
About as close as I got to checking a few hundred data sheets is the KSC 2073 which compliments the KSA 940.
Anyone have any better luck then what I have so far with converting the 2SC2238 transistor over to a new updated version?
Thanks in advance.
Thanks in advance.
10 pairs for $0.65 each, I wouldn't waste a second to order a bunch of them, BenY. (from China)
I did see those, before I posted, but I had bad luck buying semi conductors of ebay.
In that case, look at this Jacco ONE LOT OF 5 2SA968 A968 TRANSISTOR BOX#5S | eBay
These are not from China
- Replacement for 2SC2238Y
