Please help me learn from my first amp idea.
Old 6th August 2012, 05:45 AM   #1
JZatopa is offline JZatopa  United States
Default Please help me learn from my first amp idea.
So I recently built both an 02 amplifier and a 1969 JLH amplifier and have been enjoying both quite a bit. The JLH is very impressive even when compared to the F5 I built about 8 months ago but now I want to try something different. Attached is a schematic of an idea I had for an amp. I am not sure if it is a good idea, bad idea or if it would even work. My first question is, would this amplifier work as I drew it? If not, why? If the amp would work could you show me some other similar designs and tell me about their pros and cons? I am not an engineer so I don't really have anyone I could take this to to teach me about what I did right or wrong.
A little about the thought that went behind this. I started thinking about the JLH and how it might be improved. The way I understand it, NP combined the first stage and the phase splitter section of the amp to make the PLH. Instead of that I decided to try to swap in a supposedly "invisible" front end bassed on the O2 amplifier and use one of the opamps to invert the phase. I did not make any calculations and just made an assumption that if the front end can drive a pair of headphones, a pair of output devices should be just as easy. If I were to build such an amp, I would possibly use semisouth jfets on the output. I would also consider keeping the front end on it's own battery based power supply to limit noise on the front end. let me know what you guys think.
Old 6th August 2012, 08:00 AM   #2
Mooly's Avatar
Hmmm....
I can see your reasoning but I'm afraid there are problems for high quality audio with a circuit like this.
Problems.
Q1 is an NPN device and so the opamp output driving it would just turn this hard on putting supply across the speaker.
If Q1 were PNP...
The output transistors are not enclosed in any feedback network and so distortion would be very high.
There is a "dead zone" of -/+0.7 volts where the output devices are non conducting, Cross over distortion ! There is no means of accurately setting a forward bias to overcome this.
But don't let any of that put you off Keep trying and thinking and experimenting.
Edit... have a look at this circuit to see how a pair of transistors can be added to an opamp output. It's only the start though
Help with basic amp design
Please help me learn from my first amp idea.Hide this!Advertise here!
2x Gain pure op-amp headphone amp idea Dxvideo Headphone Systems 31 6th August 2017 06:09 PM
Here to learn... mattchevy Introductions 19 28th May 2011 02:59 AM
When will they ever learn ? sandyK Music 2 1st October 2009 05:31 AM
There is so much to learn dukesos Introductions 2 5th February 2009 09:13 PM
Book to learn about amp building mlihl Solid State 1 8th January 2005 11:26 AM
Copyright ©1999-2017 diyAudio
