I have a yamaha rx-496 with A-B monitoring options. Both can be selected at the same time. Would the wiring array depicted in the following diagram work to somewhat exhibit a "faux surround" similar to what was going on in the DIY home theater community in the late 80s? Excluding speaker impedance and exact values of components described in the diagram and what needs to be added still, would this work?
I have four bookshelf speakers (bought from mother in law during a move) impedance unknown at the moment, 2 Klipsch SF-2 floors and an active sub on the way. I believe that if the speakers impedance are all the same or similar I can make it work with a few transformers. Probably wont sound great but it's essentially free to me at this point, and I just want to have something until I can finish my DIY Pro Logic Decoder. ![]() I'm no design engineer so it ain't pretty, but I think I get my point across. Discrete Left and Right front channels, an LR summed center, a phase inverted LR summed mono surround pair, pots to calibrate both the rear channel and the center, and a couple switches to change from true stereo=> LCR=>(what I call)'Quasi-Quad'=>'LCRS'. My only concern is changing the load impedance in real time, I'm sure I'll need to throw in some L-pads to balance everything out. Hell, I might refit the whole lot with TRS and balance the **** outta that ****!...Probably not though... Let me know what you guys think! tbuckner |
#2 |
Anybody have any advice to lend?
#3 |
The Hafler-Dynaco faux surround audio system from the 70's is probably what you refer to. From personal experience, with unmatched speakers in several homes, it's simple phase inversion delay systems was (is) a flop. Actually, I should rather say that my implementations with a single stereo amplifier and guided by then current magazine articles, projects and suggestions were a flop.
In the early and very expensive period of Dolby surround sound, many manufacturers saw an opportunity and experimented with pseudo-surround sound processors that just added a couple of extra channels to your system with adjustable analog or digital delays. These were cheap and worked well enough, IMO, to give enjoyable surround sound from stereo sources. I dusted my 30W p/ch. add-on unit from 1990, about six months ago and it still does what is expected. Given that fully working 5.1 receivers are now just kerbside clutter and plenty of "home entertainment centre" compact audio systems have routinely had 5 channel digital sound processing in any flavour you like (also free now), is it worth the effort of resurrecting a system which never really did much?
regards |
#4 |
I hold it to be true that to really understand the growth of technology is to appreciate its current state. Being an Audio Engineer my feelings towards understanding the foundations of what most people take for granted these days is extremely important solely for the purposes of appreciating what is possible. That is not to say that I do not want to own a surround receiver. I just A) cant afford it right now and B) well that's it really...
![]() I appreciate your response but my main objective was to get feedback as to whether this design would work or not. Now I know that all of the speakers are 8 ohms. So unless my receiver can handle a four ohm load I may not be able to do this at all (unless I get crafty with series and parallel decisions while preserving the current signal flow). Anyone able to shed some objective light on my question? |
#5 | |
ok maybe this will help you a little bit in your decision, I found this post somewhere else. I am sure your receiver will not have enough juice to drive all those speakers in A+B speakers. Yamaha RX-496 Receiver won't power speakers - Audioholics Home Theater Forums |
#6 |
True, there is only 75w per channel in stereo A mode, and I remember that in A+B the output power drops a little. So yes, this will certainly under-drive my speakers. In fact, the receiver is already under-driving my Klipsch which are rated 100w RMS min @ 8ohms.
I had a feeling that this might be the case which, so I'm not too surprised to have gotten a response like lanchile has given. Perhaps I should have worded my question a little differently: Does this signal flow make sense and, excluding all nominal values, impedance values and power ratings, would wiring diagram accomplish the channel separation that I have attempted? I'm getting the feeling that I may never get my question answered and will only be told that it's silly to try an old fad, or that I would not have enough power to drive the speakers sufficiently. I had hoped that lurking somewhere on this forum there would be an electrical engineer of some sort or even a weekend DIY'er that has a better grasp on this sort of thing than I do. I just want to know if the theory behind my idea makes sense. |
#7 | |
Too many speakers...too little power ![]() http://www.nilesaudio.com/product.ph...cordID=Speaker Selectors with Volume Controls&categoryID=Speaker Selectors&catcdID=7&prdcdID=FG01043 For what I can see here is maybe you just want to be able to add and regulate volume in different speakers. if that is the case look here. PS: There are better and simpler ways to add all of those speakers and "still" have it in stereo mode! http://www.nilesaudio.com/product_de...cordID=Speaker Selectors with Volume Controls&categoryID=Speaker Selectors&catcdID=7 Last edited by lanchile; 30th July 2012 at 02:52 AM. |
#8 |
is this what you want to do? http://www.google.cl/url?q=http://ww...dDZp4myNpw4fZw
#9 |
You want this for passive surround and center with a stereo amplifier:
http://members.tripod.com/martin_lee...lerCircuit.txt Whether it works or not depends on your receiver - if it places A and B in series it probably won't work, like a couple friends' JVC and Sony receivers. I had an onkyo (A and B in parallel) that this worked fine on. High sensitivity speakers (klipsch) will reduce load on your amp, but remember to be sensible with the volume control. I put the rears on channel B and could switch in and out (I didn't have a center that could keep up at the time)
Our species needs, and deserves, a citizenry with minds wide awake and a basic understanding of how the world works. --Carl Sagan Armaments, universal debt, and planned obsolescence--those are the three pillars of Western prosperity. —Aldous Huxley Last edited by Ron E; 30th July 2012 at 03:21 AM. |
#10 |
I see now what He wants!!! I thought He wanted to just "add" more speakers to his receiver. I would measure the impedance before connecting that circuit to the receiver for sure. that pot "will" change the impedance seen by amp as it is turned and amp will be pushed even harder to drive all those speakers
| >> WTB: TDA1541A-S2 Taiwan made >> | zeroalbedo | Swap Meet | 15 | 9th August 2012 04:34 PM |
| May I have your ideas for this opamp>LCR>opamp>tube>output transformer phono stage | Witti | Analogue Source | 16 | 5th December 2011 02:37 PM |
| FOR REGA Turntable>>> The heavy weight + Vta adjuster+ceramic ball | prooptiki | Swap Meet | 1 | 22nd May 2010 05:57 PM |
| > Audio <> music <> quick <> synergy <> angst>? | rick57 | Everything Else | 0 | 4th May 2007 04:03 PM |
| >>> cheap 50,000uF 60V capacitors here >>> | Lubomir | Swap Meet | 0 | 1st February 2007 03:36 PM |
