Old 25th July 2012, 08:01 PM   #1
Default need a simple yet powerfull DIY amplifier to MJ21193G / MJ21194G power trans'
Hi , I have a 70WPC Marantz 2270 here
The preamp is perfect .
But I have troubles with the main amp
I full recapped it ,also bought a new output transistor MJ21193G / MJ21194G and still there is problem with the main amp.
I got tired of trying fixing this main amps .
I want to build a new power amp with the excelent power trans' MJ21193G / MJ21194G
can you guys recommend me a simple yet powerfull amp schematic ?
by the way the 2270 has power suplly of 45 + - DC
thanks
Old 25th July 2012, 08:25 PM   #2
Why not use the circuit of the marantz power section as a starting point ? These are usually the basic blameless topology.
The point of life is to build atleast one audio amplifier before you die.
Old 25th July 2012, 08:38 PM   #3
Its too compllicted . and it has many of Components .
I am searching of amp with a topology that match the MJ21193G / MJ21194G
because i can not product a pcb , i want it with the lowest Components number ,and yet a powerfull one at least a 70wpc
Old 25th July 2012, 10:07 PM   #4
xtechee is offline xtechee  United States
Default Do you have a serrvice manual, I do.
Would you like a copy of the amplifier schematic, and some help making the
original amps work?
Old 25th July 2012, 10:16 PM   #5
I have the service manual .
I spent allot of hours trying fixing it and just got tired...
I prefer to spend a 50$ and save my time....
I am searching for a simple amp because i can not make a pcb
and will use the generic pcb .
if I will not find I'll buy the L7 amp
Find L7 MOSFET High-speed 2 Channel FET MOSFET Power Audio Amplifier Kit Need Solder on eBay Global Buying, with worldwide deals on items in all your top categories
Old 27th July 2012, 01:33 PM   #6
WhiteRhino,
I had issues with the 2270 amp boards too - a botched repair job by a previous tech.
It took me some time, but I eventually got them going (rebuilt them), and they
sound absolutely great now.
The story is here, with a a list of replacement components which worked
for me.
https://picasaweb.google.com/prasadb/Marantz2270
https://picasaweb.google.com/prasadb...56382607434418
2270: No bias?! - AudioKarma.org Home Audio Stereo Discussion Forums
I was also looking for a suitable amp board during moments of frustration,
and considered the ebay L20 class D, ebay L7 (there's a thread on them here, I think),
the Leach amp, Symasm , Panson Audio amps and such,
which would work off the (approx) +/- 50 volt rails of the 2270.
I nearly settled for the Symasm with the MJ21193G / MJ21194G, before I got the
actual boards going.
Compact Sized LME49810/11 +ThermalTrak Amp
MY DESIGN L20D IRS2092+IRFI4020H 200W8R
A powerFULL amplifier named Dirty Harry fotios Solid State 164 2nd April 2013 02:20 PM
Simple SE using pwr trans without ct stoolpigeon Tubelab 1 24th May 2011 10:00 AM
Tubelab Simple SE: 6K7VG and XPWR033 Power Trans RGoodwin Tubelab 8 2nd November 2009 03:09 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
