TT amp, 200W/8ohm, 701W/2ohm - Page 5 - diyAudio
Old 8th August 2012, 04:08 PM   #41
Bensen is offline Bensen  Belgium
Bensen's Avatar
Originally Posted by dadod View Post
It is similar to Miller comp if TMC resistor was connected outside(directly to output) the probe. Here is screen shot with the resistor inside the probe.
Thanks for your comment.
dado
Hi D,
I see that your amp has an open loop bandwidth of only +-200Hz.
I'm currently focussing a lot on this in my design. I'm breaking my head trying to reach an open loop bandwidth op +-10Khz without using resistive loading of the VAS.
Can someone tell me if this is really that necesarry, some people are telling high open loop BW is important. But, most Solid State amps have rather small open loop BW.
Old 8th August 2012, 04:14 PM   #42
Try current feedback designs.
Old 8th August 2012, 04:16 PM   #43
Banned
i saw the diagram. It will not work! It only works when the Collector voltage is higher then the basis voltage. Because of the ripple at the collector, the collector is not always higher then the basis voltage. Besides that the whole current has to pass this transistor that produce lot of heat. After all the power supply has to have a low impedance for AC which is acchieved by the usual Condensator but in this case the impedance is the emitter resistance of the emiter which is too high..
Old 8th August 2012, 04:29 PM   #44
Banned
Originally Posted by Bensen View Post
Hi D,
Open loop high bandwidth, low gain, already low distortion with little feedback gives the best result.
Old 8th August 2012, 09:20 PM   #45
dadod is offline dadod  Croatia
dadod's Avatar
Hi D,
This is with the VAS local feedback, no resistive loading of the VAS needed, if you like that more. THD20k is the same as before, but higher at lower frequences.
dado
File Type: jpg DADO-TT-triple(vbe-bd139)-mpsa18cascodedVAS-Cmult-LG-WB.jpg (242.4 KB, 291 views)
Old 9th August 2012, 11:21 AM   #46
Here we go again.
Show us some low distortion with little feedback.
Just two days ago while working on a design this being a current feedback one I saw how damaging this low feedback myth really is. With the amp in question I found that lowering the loopgain to get wider bandwith and lower feedback causes the amp to have considerable more higher order harmonics from 4th up. TIM is also much higher.
Jlh has proved and shown this before back in the late 70s, if youre going to use feedback, better it be plenty or rather than just dont use it at all. A certain amount of feedback is necessary before the higher order harmonics are lowered so in fact low feedback is the worst you could do as it will cause them to be higher instead of lower.
Old 9th August 2012, 11:32 AM   #47
Banned
its up to you. Seeing the level here I will not proceed to defent this statement.
Old 9th August 2012, 05:10 PM   #48
Bensen's Avatar
dado
Interesting, the local feedback to IPS is done with the 10Meg resistor if see it correct?
I'm gonna play arround with this a bit.
Greetz
Old 9th August 2012, 05:40 PM   #49
a.wayne is offline a.wayne  United States
Sin Bin
Originally Posted by homemodder View Post
Here we go again.
OK... Now define how much is low, how much is enuff vs a lot ...
Yeah ...
Old 9th August 2012, 06:22 PM   #50
dadod's Avatar
Greetz
Yes this is R20 10Meg resistor making local FB from the Q15 collector(cascode transistor) to the Q12 base(VAS transistor).
dado
Simple, powerful (100W-200W into 8ohm) amplifier schematic needed ddog Solid State 15 11th July 2013 11:04 AM
200W @ 8OHM Class D HiFi Stereo Amp sssuneth Class D 1 27th January 2012 09:23 PM
Can (Elektor) PA300 amp drive 2ohm load goldyrathore Solid State 0 11th June 2010 04:21 PM
8ohm resistor in series with 8ohm speakers for a 16ohm OT? Reidy- Tubes / Valves 8 10th January 2010 11:25 PM
12" 2ohm round Solobaric TS Parameters dok33 Car Audio 1 15th May 2004 09:00 PM
Copyright 1999-2017 diyAudio
