TT amp, 200W/8ohm, 701W/2ohm
Old 8th August 2012, 01:47 PM   #31
dadod is offline dadod  Croatia
dadod's Avatar
Those are correct data:
ULGF = 1MHz
RL = 4ohm, Pout=330W
THD1k = 7ppb
THD20k = 1.33ppm (1.08ppm, RL = 8ohm)
THD50k = 15.72ppm
THD100k =0.009624%
THD200k =0.061653%
RL = 4k, THD20k = 0.77ppm
PM = 92 degree
GM = 15dB
Old 8th August 2012, 01:48 PM   #32
Dave Zan is offline Dave Zan  Australia
Hi Dado
Nice work.
I am a bit surprised by the loop gain plot. After heated debate in earlier threads I think that finally there was consensus that TMC is a second order system and that the similarity to (1st order) Miller comp in the outer loop is deceptive. The loop gain plot that sets the stability limit should show second order behaviour and I don't see that.
Is there some explanation?
Best wishes
David
Old 8th August 2012, 01:58 PM   #33
dadod's Avatar
Originally Posted by Dave Zan View Post
Hi Dado
Nice work.
Best wishes
David
It is similar to Miller comp if TMC resistor was connected outside(directly to output) the probe. Here is screen shot with the resistor inside the probe.
Thanks for your comment.
dado
Old 8th August 2012, 02:15 PM   #34
dadod's Avatar
Here is low power version.
ULGF = 1MHz
RL = 8ohm, Pout=95W
THD1k = 1.09ppm
THD20k = 1.74ppm
THD50k = 16.15ppm
THD100k =0.014506%
THD200k =0.114467%
PM = 90 degree
GM = 15dB
It is quite simple, specialy if capacitance multipliers for OPS were removed and powered with +-45 V instead.
dado
Old 8th August 2012, 02:19 PM   #35
liching1952 is offline liching1952  Switzerland
Banned
what is a C multiplier?
Old 8th August 2012, 02:35 PM   #36
Thank you - that plot is much more informative. The outer loop plot always looks like Miller compensation so it is deceptive without an explanation.
Best wishes
David
Old 8th August 2012, 02:40 PM   #37
Capacitance multiplier - Transistor connected to a capacitor to "multiply" the effective capacitance.
Best wishes
David
Old 8th August 2012, 02:47 PM   #38
Banned
Best wishes
David
It what kind of application is that used? You get the the nonlinearity and limitations of the transistor for free as bonus.
Old 8th August 2012, 02:54 PM   #39
Banned
and why not just use a bigger C instead of a C multiplier?
Old 8th August 2012, 03:52 PM   #40
dadod's Avatar
You can search this forum, it was written quite a lot about capacitance multiplier here.
TT amp, 200W/8ohm, 701W/2ohmHide this!Advertise here!
Simple, powerful (100W-200W into 8ohm) amplifier schematic needed ddog Solid State 15 11th July 2013 11:04 AM
200W @ 8OHM Class D HiFi Stereo Amp sssuneth Class D 1 27th January 2012 09:23 PM
Can (Elektor) PA300 amp drive 2ohm load goldyrathore Solid State 0 11th June 2010 04:21 PM
8ohm resistor in series with 8ohm speakers for a 16ohm OT? Reidy- Tubes / Valves 8 10th January 2010 11:25 PM
12" 2ohm round Solobaric TS Parameters dok33 Car Audio 1 15th May 2004 09:00 PM
