class A amplifier on 12V car rails
Old 25th July 2012, 07:31 PM   #1
muddasirwaheedmalik is offline muddasirwaheedmalik  Pakistan
Default class A amplifier on 12V car rails
hi , is there any simple class A low wattage amp design using single car 12v rail, no DC/DC switching no EMF shielding etc, i assume with 12V one can get 12x12/4=36W maximum disspation though which i can get 18W , classA into 4Ohm and may be 36W into bridged ??? any idea ???
Old 25th July 2012, 08:24 PM   #2
Tekko is offline Tekko
Banned
5 watts per channel in 4 ohms and 20 watts absolute max bridged in 4 ohms.
Old 25th July 2012, 08:27 PM   #3
Loudthud is offline Loudthud  United States
Loudthud's Avatar
With a 12V rail you can create an AC waveform of 12V peak to peak. That's about 4.2V RMS or just over 4 Watts into 4 ohms. Look for the "Amp Camp Amp" in the Pass forum. It will run on 12V but for 4 ohms you will have to increase the idle current.
Old 26th July 2012, 01:30 AM   #4
CBS240 is offline CBS240  United States
CBS240's Avatar
I had a car amp once, Forum or something like that, had two fairly large EI transformers in it. Curiosity got me to investigate the circuit, it used the 12V B+ from the car and drove a step up output transformer in push-pull class AB. 50W per ch. There was no SMPS.
All the trouble I've ever been in started out as fun......
Old 26th July 2012, 08:01 AM   #5
Bone is offline Bone  United Kingdom
Use the JLH design as original. Works fine on 12v. use resistor values for 17v. Been there done it. Sounds great. Kit here on ebay 2pcs JLH 1969 A CLASS A amplifier kit sc | eBay . Note this is for 24 v.
See original article here The Class-A Amplifier Site . I used transistors 2N3906, BD139 and 2 x 2n3055s. Gives about 3.5 watts
Old 26th July 2012, 09:50 PM   #6
davidsrsb is offline davidsrsb  Malaysia
Car "12V" is actually 13.5~13.8V when the engine is on and car amps are specified at this higher voltage.
class A amplifier on 12V car railsHide this!Advertise here!
12V Car Amplifier.. deepanger Solid State 24 14th February 2011 09:50 PM
Best TDA Chip For 12V Car Audio Amplifier livenicely Chip Amps 7 1st December 2010 04:26 PM
P3A on +/-12V rails 00940 Solid State 6 5th March 2008 12:44 PM
Does anyone know a bridged design for 12v rails? mpmarino Solid State 3 16th June 2007 11:37 AM
Class AB car amp, switchmode power supply, what rails?? SkinnyBoy Solid State 4 8th December 2003 02:26 PM
