diyAudio
diyAudio (http://www.diyaudio.com/forums/)
-   Solid State (http://www.diyaudio.com/forums/solid-state/)
-   -   2x70v supplied amp (http://www.diyaudio.com/forums/solid-state/216660-2x70v-supplied-amp.html)
kallamash 23rd July 2012 05:16 PM
2x70v supplied amp
Hi, I am about to build my first power amp, I robbed two good 130VA transformers from old blown Tesla rack amps. These amps looked quite fine, used in the theatre before trannies friyng. So I measured output of PSU and got there 2x70VDC. It is quite hard to find circuit, matched for this psu. Because it is my first amp, I am looking for something simple, but discrete, more precise then powerfull. Any suggestions?
moschfet 23rd July 2012 05:47 PM
Hi kallamash,
are you sure, that the Power of the transformers are only 130VA?
This is very weak for 70V... about 900mA per voltage.
With this one you can build VAS, the voltage amplifier.
Power is the condition for precision ;)
For example, better 2 x 25V and 10A than 2 x 70V and 0.9A.
kallamash 23rd July 2012 09:27 PM
Thank you Moschfet, I think these transformers might be more powerfull to, I calculated VA ratings longer time ago, It is really possible I got it wrong, because amps were rated for 100W for 16ohm. Each one weights about 2kg. If it will be helpfull, original psu was equipped by 2 500u 100v cap on each rail and amp was dead silent.
kallamash 24th July 2012 01:39 PM
Ok, fuse on primary was rated for 2A.
djQUAN 24th July 2012 03:08 PM
I think the amp is originally designed for 70V PA lines where the amp drives transformers before the speakers. Those transformers won't be enough for amps that drive speakers directly, not enough current.
AudioSan 24th July 2012 03:37 PM
those transformers can be fine for a pre-amp:) f.ex. pass aleph P1.7 or Bosoz:)
build a +/- 60V regulated PSU(for bosoz) or +60V regulated PSU(for P1.7)
wahab 24th July 2012 04:04 PM
Even if the transformers are within current specs for use with an amplifier
loaded with 8R , i wouldnt recommend as first build an amp with +-100V
rectified supply voltage.
kallamash 24th July 2012 04:45 PM
Originally Posted by djQUAN (http://www.diyaudio.com/forums/showthread.php?p=3102873#post3102873)
There is an transformer on the output, I though it is step up for long speaker lines at first, but this is step down Interesting coil it is. http://www.imagehosting.cz/images/dsc03190.jpg
There is no way I will find good diy amp scheme designed this way.
Is 140V enough for tube amp?
Originally Posted by AudioSan (http://www.diyaudio.com/forums/showthread.php?p=3102904#post3102904)
Thank you, but I don't need an preamp right now. I will sell them or keep them in the closet, until their time will come.
Copyright 1999-2017 diyAudio
