In the picture attached you will find a resistor to ground and another section with a capacitor/resistor to ground. What is the purpose for this type circuitry?
#2 |
With the two diodes above it, it forms a voltage reference, referenced against the upper supply rail, resulting in Vsupply - 2x diode drop.
Negative Feedback: The Need for Speed |
#3 |
R-C: Boucherot cell
#4 |
Thanks gentlemen.
#5 |
Without R621 there would be no current through the diodes and they would just sit there rather stupid
![]() jan didden
/Yes! Its out: Linear Audio Vol 5! I'm not an "accademic", just a plodder who loves a challenge - Ian Hegglun |
#6 |
I agree with BV. An alternative name is Zobel (not sure of the spelling) network.
I believe that it ensure that the output stage is loaded by a low impedance that helps to control the high frequency gain of the output stage so helps to maintain stability. Another reason that I have read is that it partly compensates for the inductive part of a typical loudspeaker load. |
#7 |
Could I also refer to the R-C combo in my schematic as a snubber?
#8 |
A snubber is used to snub or quench a transient or arc. They are normally used across a switching element and a current will shunt through it as the switch starts opening (not closing) so that an arc will not form across the contacts.
A zobel is a network that if placed at the input of a filter network and if looking into the filter, it appears as a constant impedance over a wide frequency range.
Kindest regards Nico |
#9 |
The RC combo is there to help reduce DC offset is it not? The cap is high impedance at low frequencies lowering the gain?
I thought about it once, but then thought again. |
#10 |
This RC is Zobel at output.
| purpose and value importance of resistor | CoolJazz | Tubes / Valves | 15 | 12th April 2012 05:26 PM |
| Purpose of series input resistor in guitar preamp? | miallen | Solid State | 14 | 17th December 2010 10:42 AM |
| a resistor to ground? | lanchile07 | Chip Amps | 11 | 23rd November 2007 02:16 PM |
| Parallel LM3886, input ground, power ground, safety resistor and oscillations. | markiemrboo | Chip Amps | 5 | 9th August 2007 03:50 PM |
| general purpose relay to mute/ground outputs | mazurek | Parts | 1 | 27th February 2006 02:29 PM |
