Musical Fidelity A100 - convert to power amp?
Old 18th July 2012, 01:32 AM   #1
Gratidude is offline Gratidude  Canada
Default Musical Fidelity A100 - convert to power amp?
Greetings,
I have a Musical Fidelity A100 integrated amp with a input switch that needs replacing (sounds like dirty contacts in the switching mechanism). Id like to convert the unit into a power amplifier if I could figure a way to short the CD input (or any other line level input) straight through to the amp section. I'm fearless with a soldering iron, but I lack the confidence when it comes reading the schematic. I'd very much appreciate any tips.
I've studied the schematic supplied by Musical Fidelity A1
Could I kindly ask the community for some advice here can this operation be done?
Thanks,
Pete Jones
Vancouver, BC
Old 18th July 2012, 01:55 AM   #2
lanchile is offline lanchile  United States
lanchile's Avatar
Sure it can be done! But that integrated amp looks very good. I would "fix" that input selector or change it. also I would change those old electrolytic capacitors. That is a very nice integrated amplifier for sure.
Old 18th July 2012, 03:02 AM   #3
Indeed - I'm looking forward to replacing capacitors and loving it up in every way I can. I enjoyed several months of glorious sound before the input selector died. I use the preamp in my tubeDAC and think there would be no advantage to keep the A100 preamplifier in the signal path. I have no need for anything but a poweramp function from this unit. I imagined that a careful solder job would do the trick - if I knew where to point the thing!
Musical Fidelity A100 - convert to power amp?Hide this!Advertise here!
Musical Fidelity A100 fans willholmania Solid State 4 18th December 2014 02:18 AM
Musical Fidelity A100 Help Needed king10 Solid State 5 26th September 2012 09:21 AM
Musical fidelity A100 adespade Solid State 1 26th February 2012 02:09 PM
a dead Musical Fidelity A100 otaku Solid State 58 14th August 2010 06:27 PM
Musical Fidelity A100 problem. willholmania Solid State 2 23rd July 2010 07:08 AM
