Old 28th September 2012, 12:04 PM   #11
Jitter,
Thank you so much for providing the manual and such a speedy reply
I took your advice and metered from the mains plug to the pins on the board (going to the main trans).
The N line was ok
The L line was O/C
Briefly checking the drawings, this has drawn me to relay RY401, and to find why this is not firing. I have not managed to carry out any further checks as yet.
Jaycee,
Your reply came through just as I was about to start a night shift.
Therefore, I have not managed to do any tests yet, but have spent some time looking at the drawings of the Subtrans circuit and trying to follow them through.
Thank you so much for your valued input, suggestions and explanation of what is going on here. I have only briefly managed to look at the board and the components you have mentioned, but cannot see any obvious signs of damage. When I have a little more free time, I will do some more tests and feed back.
Thank you both again for your much needed help.
Tristo
Old 28th September 2012, 05:27 PM   #12
jitter is offline jitter  Netherlands
jitter's Avatar
You're welcome. You didn't mention the fuse, but I assume it's OK.
I've been trying to get my head around the PSU of this amp, but it gave me a headache. On the plus side is that the schematic has links (the yellow boxes) so you needn't scroll until you're blue in the face...
The way I see it is that the subtrans powers the microprocessor (uP) via S10 to IC501 to +5M/+5S/+5BU and is checked by the very same uP (PDET might mean Power DETect). At power down PDET becomes low quickly (before the main PSU caps have drained) and the uP will probably switch off the speaker relay te prevent strange noises and thumps.
C402 probably creates a slight delay after power on before the uP gets reset (/RES).
If subtrans power is up, than the uP activates PRY (which I assume means Power RelaY) and that switches on RY401 to connect the main transformer to the mains.
I agree with jaycee that the subtrans is the place to start measuring. It is on page 86 (not 81) top right. If it doesn't work, the rest of the amp can't work either.
Old 28th September 2012, 06:22 PM   #13
Jaycee is correct, change C405 and all your woes will be sorted.
James.
"An AudioPhool and Proud of it!!"
Old 28th September 2012, 06:41 PM   #14
jitter's Avatar
Sorry, but because of my job in electronics, I don't agree with replacing parts on a hunch. Measure first.
Old 28th September 2012, 07:02 PM   #15
My job is electronics too.
I repair Hi-Fi's for a living. I repair lots of Yamaha Amplifiers, Sound Bars etc etc.
C 405's value changes and does not pass as much AC through it to IC 402 as it should preventing the Standby Circuit from operating correctly.
Not a hunch.
James.
Old 28th September 2012, 07:05 PM   #16
See here also
Yamaha YSP-1000 - Power problem | AVForums.com - UK Online
Similar power supply. Same Cap.
No hunches were harmed in the writing of this post.
Old 28th September 2012, 07:28 PM   #17
jitter's Avatar
That makes things different.
My job is in industrial electronics (manufacturing) and indeed, for certain relatively often occurring faults in a product I'm specialized in, i just know what to replace without taking any measurements.
If C405 is a well known offender in these products, then I'd agree on replacing it anyway. I would also consider this a flawed design and I hope Yamaha doesn't use it anymore.
Old 28th September 2012, 07:31 PM   #18
Many many thanks to everyone who has taken the time to look at the drawings and help diagnose this for me. I have learnt a lot in the last 24 hours.
I am currently not at home so cannot do any checks atm, but I am pretty confident that cap seems to be this issue. I'm lucky enough to live near a maplins, so I will let you know how I get on.
One last quick question. We had a couple of power spikes at work last week. Do you guys think this could be the cause of the damaged cap? Or is it just worn out through normal use? I'm pretty sure the amp is plugged into a surge suppressor extension lead to protect against this.
Thanks again,
Tristo
Old 28th September 2012, 07:53 PM   #19
jitter's Avatar
It's the function of X- and Y-rated caps to prevent damage to equipment and injury to persons (link).
For obvious reasons these should never go short circuit in case of damage. That leaves decreased capacitance as a failure mode. Those spikes may well have caused damage to the caps, esp. if the malfunction occurred shortly after. Replace only with the same type!
I've heard of damage to equipment plugged into surge suppressors before, so I question if their capability of protecting against spikes.
I think "normal wear" would need at least a decade to appear. At work we had a lab power supply belch out smoke as a result of a failed suppression cap on the mains entrance. Within a few weeks, another one of same make and age developed the same fault. These PSUs were well over a decade old and in daily use.
Old 2nd October 2012, 11:20 AM   #20
Smile Fixed
A big thank you to everyone who helped with my issue.
On Sunday I replaced C405 with a new one purchased from Maplin (N38CN / 89p)and unit fired up perfectly. The original cap look fine and had no obvious signs of damage, but when tested, was only reading 6.6nF and not the stated 22nF.
The new capacitor is rated for 1250V, a lot higher than the 630V specified.
Do you guys recommend that I change it again for one of the correct rating, like the one linked to by Jaycee in an earlier post?
I will have to get this capacitor mail order, which Is why I went for the Maplin one originally.
Thank you all again for all or your help.
You have certainly saved me a lot of money getting the amp sent away and tested.
I will definitely be recommending this forum to friends and family and be checking back here again.
All the best
Tristo
yamaha dsp a1000 swiching on and off homertooties Solid State 13 13th June 2012 07:12 AM
Faulty Yamaha DSP-A2070 RishiGuru Solid State 6 2nd June 2012 06:03 AM
Yamaha DSP-A595 Mod lectrolux Chip Amps 3 23rd January 2011 10:28 AM
mod a Yamaha DSP A5 Yaka Digital Source 0 10th February 2008 06:31 PM
YAMAHA DSP-A2 Schematic palesha Solid State 7 23rd December 2005 04:09 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
