Old 16th July 2012, 04:49 AM   #1
ChrisA is offline ChrisA  United States
Default Chassis design for SS amp.
Looking for advice (or links) on the mechanical design and chassis for a testbed SS stereo amp.
I want a good size chassis with heat sinks suitable for a 200 WPC amp. I'll build the amp modular using sub chassises that can be swapped out. The idea is to try out different ideas and evolve the design over time.
I'm new to SS amps. I'm used to building with tubes and have my own preferred contraction technique for use with tube amps. I'll have to figure out how I like building SS amps. But I need some suggestions about where to find the chassis parts
Old 16th July 2012, 05:15 AM   #2
modu Look pretty decent and were recommended by Andrew "Bonsai".
Best wishes
David
Old 16th July 2012, 08:46 AM   #3
Bonsai is offline Bonsai  Taiwan
Bonsai's Avatar
Yes, they are pretty reasonable for the money in my view - though not to the highest finish standards. I thought the diyAudio store was going to carry them in the USA - I just took a quick look and could not see anything - maybe a moderator can update us on the status.
bonsai
Amplifier Design and Construction for MUSIC! http://hifisonix.com/
Old 16th July 2012, 02:10 PM   #4
tiefbassuebertr's Avatar
check out this thread:
Passlabs Preamp Envelope Design - High-Grade Outline by only 10 parts except Screws
Old 16th July 2012, 08:24 PM   #5
indianajo's Avatar
Depending on your budget, I founds tons of heatsinks attached to the motor drives that went into the dumpster at the food plant I last worked at. Sanitation tended to squirt them with high pressure hoses and blow them up. So if you have a friend that works maintenance at a food plant, buy him a six pack or something and get into the trash stream. Motor drives have fans, 24 v relays, and power conditioning devices, also.
Most of the motor drives had plastic cases, a dozen or so (Heat and Control) had stainless steel cases with power disconnects and heat sinks on the back, which look really cool but don't keep the RF out. I've been picking up recipe files and personal files out of magnetic steel for enclosures, the ones with a hinged top. I have my own drills and conduit punches, and cut square or oversize holes with a diamond dust drill bit or a carbide hacksaw blade (round) to connect the dots of small drilled holes. You need a dirty shop with a vise, as steel dust is bad for the electronics bench.
Dynakit ST70, ST120, PAS2,Hammond H182(2 ea),H112,A100,10-82TC,Peavey CS800S,1.3K, SP2-XT's, T-300 HF Proj's, Steinway console, Herald RA88a mixer, Wurlitzer 4500, 4300
Pics of unique design of amp chassis? Doug Kim Tubes / Valves 33 6th January 2013 09:23 PM
SS amp design component starter kit cbdb Parts 5 11th October 2011 04:52 PM
What to read on SS amp design? Nevod Solid State 6 27th August 2008 08:25 AM
What to read on SS amp design? (valve-ish style) Nevod Pass Labs 1 27th August 2008 07:16 AM
Output transformer design for SS amp Tyimo Tubes / Valves 12 17th January 2007 01:02 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
