Adcom GFA-585 HELP NEEDED! Adcom GFA-585 HELP NEEDED! - diyAudio
Old 17th October 2003, 01:06 AM   #1
georgehifi is offline georgehifi  Australia
georgehifi's Avatar
Send a message via MSN to georgehifi
Default Adcom GFA-585 HELP NEEDED!
I`ve been trying to get this amp running properly now for long time and it now seems that a previous repair was not done correctly, the zener diodes near the input that are Adcom specials, (look like transistor), may been replaced with the wrong value, the zener diodes left channel are d111,d112,d113 and d114, the right channel are d161,d162,163 and 164.
Does anyone know or can measure the correct voltage of these zener diodes for me so i can finally get this amp up and running properly.
Cheers, manly thanks from downunder in Australia, George.
Avatar : Production Lightspeed Attenuator
www.lightspeedattenuator.com
Old 17th October 2003, 02:08 AM   #2
Tube_Dude is offline Tube_Dude  Portugal
Tube_Dude's Avatar
Default Re: Adcom GFA-585 HELP NEEDED!
Are you shure that they are zeners and not transistors???....is not usual so much zeners at the input of a amplifier...
As they are 4 for each channel it seems that they are a double diferencial (double LTP)...
Jorge
Old 17th October 2003, 04:03 AM   #3
georgehifi's Avatar
Oh, yeah their zeners alright, not right at the input but close, i`ve got the circuit, if only i knew how to post the circuit diagram i`d put it on one of these posts so you guys could see it, is it easy as i`m hopless on a computer. (Yeah they look like transistors three legs but two are linked together on the board.)
Old 17th October 2003, 04:06 AM   #4
Tube_Dude's Avatar
you say that they look like transistors...Why?...they have 3 pins?
Jorge
Old 17th October 2003, 04:10 AM   #5
li_gangyi is offline li_gangyi  Singapore
li_gangyi's Avatar
They might be zeners...with those transistor packaging...commonly known as voltage references...but I'm not sure if they are used in amps...
Kids in the back seat cause accidents...Accidents in the back seat cause kids...
Old 17th October 2003, 05:15 AM   #6
ben goh is offline ben goh  Singapore
Send a message via AIM to ben goh Send a message via Yahoo to ben goh
Default adcom
try this link
http://www.diyaudio.com/forums/showt...280&highlight=
Old 17th October 2003, 05:56 AM   #7
georgehifi's Avatar
Nuh, Ben, good try but the gfa-555 is a different circuit to the 585, can anyone tell me in simple english how to post the circuit i have for the 585 it might help to get to the value of the zener diodes.
Cheers
Old 17th October 2003, 06:39 AM   #8
Hi George,
U can try scan the schematic with a scanner with a PC attached
or use a digital camera to take several portion.
Old 17th October 2003, 07:09 AM   #9
djk is offline djk
djk's Avatar
This look familiar?
http://www.diyvideo.com/forums/attac...p?postid=66400
Old 17th October 2003, 07:25 AM   #10
georgehifi's Avatar
Yep, very close, what model is that? it`s almost the same, the zener diodes are the ones in the bottom left corner.
Can anyone now let my know what voltage zeners they are?
Cheers George. Thanks DJK!
Adcom GFA-585 HELP NEEDED!Hide this!Advertise here!
Adcom GFA-545 II Schematic Needed 1moreamp Solid State 4 18th September 2012 03:11 AM
Adcom GFA 585 Driver PCB needed Fearlessleader1 Parts 1 20th December 2005 09:09 PM
Adcom GFA-585 Parts Needed wilsonmw Parts 2 14th July 2005 05:09 PM
Adcom 555 amp fuse help needed hellotheworld Solid State 4 12th October 2004 07:02 AM
Adcom Schematic Needed Gfa-545 Ii Mattyo5 Solid State 8 12th June 2003 03:56 PM
Copyright ©1999-2017 diyAudio
