Picking replacement output devices for Yamaha M-45
Old 9th July 2012, 09:29 PM   #1
geaugafletcher is offline geaugafletcher  United States
geaugafletcher's Avatar
Default Could use a hand - Picking replacement output devices for Yamaha M-45
There was a mishap with a slipped meter probe and a bright blue flash, more about that in a minute...
I'm assuming that the output transistors are toasted; they are 2SC3182 and 2SA1265. A search on Mouser lead me to this pair of Fairchilds:
http://www.fairchildsemi.com/ds/2S/2SC5242.pdf
http://www.fairchildsemi.com/ds/FJ/FJA4213.pdf
...which look like viable replacements. Are they good substitutes? Also, should I get the "O" or "R" version? (The hFE ratings are different between the two.) This amp is one of Yamaha's class AB/A where a switch on the faceplate biases the output devices into class A up to 10W, according to the literature. I don't know enough about circuit design to know if the Fairchilds will work in that situation. The schematic will be posted this evening, if need be.
So about the slipped probe, I shorted the "upstream" end of the emitter resistor to a jumper that ties into the corresponding transistor's collector. Most likely the drivers are toasted, too? I have yet to disassemble the amp and do any testing. The main 10 amp fuse blew right away. No semiconductors have burn marks - the board has a black mark; the resistor's lead and the jumper both have divots from the short.
Old 10th July 2012, 05:55 AM   #2
Datasheets for the originals:
http://www.datasheetcatalog.org/data.../499646_DS.pdf
2SC3182 datasheet(1/2 Pages) TOSHIBA | SILICON NPN TRIPLE DIFFUSED TYPE
Picking replacement output devices for Yamaha M-45Hide this!Advertise here!
KEF 104/2 selling advice (+kube, +YAMAHA M-45 en C-45) Dytoonn Multi-Way 6 29th April 2012 12:14 PM
Yamaha M-45 Power Meter Mods gni Solid State 7 7th October 2011 04:05 PM
help with vifa d27tg-45-06 replacement MC Dig Multi-Way 14 8th April 2009 01:38 AM
Yamaha M-45 Blown Output Transistors gni Solid State 35 29th July 2008 10:47 PM
Replacement devices for Citation 16 G Solid State 1 25th November 2002 05:00 PM
