Popping Crate GX-130C
Old 6th July 2012, 12:26 PM   #1
MemphisMerv is offline MemphisMerv
Default Popping Crate GX-130C
Hi! I have a Crate GX-130C combo that pops quite loudly after it's been on for a few minutes. I see the channels switch on their own when it pops as well.
Any idea's, or suggestions? I'm quite handy with a soldering iron.
THANKS!
Old 6th July 2012, 02:00 PM   #2
Osvaldo de Banfield is offline Osvaldo de Banfield  Argentina
Osvaldo de Banfield's Avatar
Location: Barrio Garay,Almirante Brown, Buenos Aires, Argentina
At first, change the electrolytic caps. One or more of them may be faulty, leaky or degraded. More important are coupling caps, and power supply ones.
Osvaldo F. Zappacosta. Electronic Engineer UTN FRA from 2001.
Argentine Ham Radio LW1DSE since 1987.
Old 6th July 2012, 04:40 PM   #3
would that be all the electrolytics on both the pre and power amp board?
Now that I've asked that question, here's another.....
I left the thing on, and noticed that the chorus section kicks in intermittently. I wonder if that has anything to do with this as well....
Granted I got this thing CHEAP (40 bucks) but I'm beginning to wonder if it's worth all the time/materials to mess with it...
Old 6th July 2012, 05:31 PM   #4
I always replace electrolytics by a group of 5, no more with a switch on between any group. So if you do a mistake, are sure that it is in the last group.
Surely. coupling caps with leakage may have erratic job.
Old 6th July 2012, 11:12 PM   #5
Ian Finch is offline Ian Finch  Australia
Hi! I have a Crate GX-130C combo that pops quite loudly after it's been on for a few minutes. I see the channels switch on their own when it pops as well....
It seems a bit more than the usual problem with old caps. It is throwing logic controlled switches so there is likely quite a disturbance on the low level supply rails.
'Need a schematic, I'm afraid. Meantime, scope the preamp and main power rails if you can, to see if there is something going on there.
However, this might be interesting regarding connectors too.
Ian
Old 15th August 2014, 01:00 PM   #6
guitarmate is offline guitarmate  Canada
Is anyone still following this thread?
I was given this Crate amp and love the chorus, so creamy.
Unfortunately I originally only got the bare chassis. I now have the rest but the reverb is disconnected.
I need to find which spade lugs to reconnect the reverb to.
I have seen photos online but all have been to blurred to tell which connection to use.If anyone could take a photo of the connections I would appreciate it
Popping Crate GX-130CHide this!Advertise here!
Akai GX-95 Mikewong Analogue Source 25 23rd June 2013 12:21 AM
Orion 280 gx mike49504 Car Audio 10 31st January 2010 04:24 AM
Crate GX-80 Bad Input achipola Instruments and Amps 0 2nd November 2008 10:48 PM
Akai gx f-31 Iagent Everything Else 0 2nd November 2007 07:30 PM
Copyright ©1999-2017 diyAudio
