The amp when you power it on and hasn't got input, it makes a sorta hiss/static through its speakers, its in both but louder on the left.
Then when you put in an input, the left is very weak compared to the right.
This is a cap coupled output amp, could the output caps be at issue ?
Is there a filtering cap, and could it have given up ?
Where can I find a schematic for it ?
Thanks to all.
Srinath.
Thanks to all.
Srinath.
