Impedance
Impedance
Old 4th July 2012, 02:54 PM   #1
michouthefirst is offline michouthefirst  Canada
Default Impedance
I would like to find a good article on impedance in solid-date circuits. An article going deep on impedance, particularly concerning different stages of signal amplification (both small and large).
An article containing in-depth discussions, circuits and equations would be perfect.
Thanks all!
Old 4th July 2012, 06:40 PM   #2
Mooly's Avatar
Impedance
I would always recommend the books by Doug Self and Bob Cordell as these are audio specific.
Something like "The Art of Electronics" by Horowitz and Hill covers a lot of ground too.
"Impedance" is a large subject but with a good grounding in the subject you can apply that knowledge to most situations, particularly audio.
If you have a particular question on a particular circuit then maybe we can help on that.
Old 5th July 2012, 01:16 AM   #3
Thanks for the info. I have some books by the authors you mentioned. I will have a look.
Thanks again.
ImpedanceHide this!Advertise here!
SET output impedance vs speaker impedance Arno Pf Tubes / Valves 3 20th April 2012 07:37 PM
Impedance rate VS impedance stability TomatoBangBang Tubes / Valves 6 4th September 2008 10:46 PM
pri. impedance vs. sek. impedance tyor Tubes / Valves 7 29th August 2007 10:52 AM
Need help understanding transformer impedance ratios and impedance matching percy Tubes / Valves 5 28th February 2005 08:35 PM
help! impedance! electro samurai Chip Amps 10 19th April 2004 03:52 PM
