Old 28th June 2012, 06:17 PM   #1
vsat88 is offline vsat88  United States
Default HCA 1206
Hi, as I am new to the forum I hope I am not breaking any rules. I did look very carefully and read all I could find before posting. I have an HCA-1206 and have ordered new caps for it however I need a schematic and would like to know the correct voltages to reset the pots on all six channels to bias the transistors properly. Any help with this would be greatly appreciated. I am somewhat familiar with electrical work however you can probably tell I am not a tech. I love this amp. and really want to fix it to use as a "surround" amp. for my PC. Thank you !
Best regards, Jim Jr.
Old 29th June 2012, 12:21 AM   #2
Installed the caps today and the amp sounds incredible ! Of course it would not take much considering what I was running after my Kenwood basic M2 took a plunge. (a realistic MPA-250 LOL) well gotta do what you gotta do ! At least I have a good boat anchor ! Thanks for the views as I really love the Parasound and would still like to set the pots if I can. One thing really bad happened though. I was not paying attention and hooked some wires up wrong on re-assembly and fried a channel . O well looks like a five channel amp for now...
Old 29th June 2012, 10:37 AM   #3
Things have gotten worse..(help please !) Awoke this AM and started the day with coffee and Pachelbel. Well, I had coffee at least..Now the current overload protection light for channel one is coming on and it sounds like a relay is clicking on and off inside the amp. Looks like I may be working in reverse, getting worse instead of better..:0
Old 9th July 2012, 01:12 AM   #4
Wow, From guys and gals on here I really did expect someone would have given advice as to where I could find the schematic for this amp by now...Oh well I found the issue and corrected it fully and the amp sounds well....incredible. Now if I could just find the values / voltages so I could set the pots...... Thanks to all that took your time to check my post !
Old 15th July 2012, 11:59 AM   #5
Tony @ Parasound gave me the mv. settings I needed for the amp. as well as some great advice. Thanks for allowing my post on your site.
parasound HCA-1206 (Tony at Parasound.com) ostie01 Solid State 1 10th July 2012 05:24 AM
Parasound ( John Curl ) 1206 upgrades? dgeldart Solid State 0 22nd December 2011 02:19 PM
Popped the top on my new to me parasound 1206, and I am glad I did AJ Bertelson Solid State 2 30th March 2011 02:36 PM
Parasound HCA-1206 6-channel amp and Behringer CX-3400 active xover wigginjs Swap Meet 6 16th October 2008 01:43 PM
Epcos SMD 100 nF 1206 X7R capacitors jean-paul Swap Meet 3 8th May 2006 06:12 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
