Active highpass filter
Old 28th June 2012, 05:33 PM   #1
dincz is offline dincz  Czech Republic
Default Active highpass filter
I'm trying to modify the high pass filter in a microphone preamp to drop its -3dB point from 75Hz to 40Hz. The original schematic is attached.
Should I simply increase the values of R24 and R25 keeping them equal, or is that likely to mess something up? Online filter calculators I've looked at seem to use a 2:1 ratio for these two resistors. What is the significance of this ratio and what are the effects of varying it?
Old 28th June 2012, 11:47 PM   #2
Irakli is offline Irakli  United States
Irakli's Avatar
Just google "unity gain sallen key filter". Even a Wikipedia page is very helpful.
My System
Old 29th June 2012, 12:38 AM   #3
djoffe is offline djoffe  United States
assuming that everything about the first filter was as you wanted, except for the cutoff frequency, you could just increase the resistors by a factor of 75/40.
Alternatively, you could increase the capacitors by the same ratio...It's just usually easier to get closer with resistors.
Old 29th June 2012, 08:39 AM   #4
Thanks for the replies. I had already searched the web - including Wikipedia - but the answer seemed to be buried in layers of stuff way beyond me. Spent a few minutes with a design engineer this morning and problem solved.
Apparently changing both resistors (or capacitors) by the same amount just shifts the cutoff frequency, whereas changing their ratio alters the shape of the knee.
Active highpass filterHide this!Advertise here!
Highpass Filter Help Needed Greg M Multi-Way 5 19th May 2011 11:20 AM
Breadboard amp = echoes + highpass filter? dopeydavoid Solid State 2 12th April 2011 12:50 PM
Highpass filter via feedback cap scottw Chip Amps 12 24th October 2009 11:20 AM
Active highpass filter - ground skogs Analog Line Level 3 19th June 2007 06:25 PM
Highpass filter using sound card??? vsboxerboy Digital Source 0 18th July 2005 08:59 AM
