#21 | |
#22 | |
As wire resistance and inductance.
lineup |
#23 |
You can model the parasitics. The inductances around the output and drive stages are particularly important, but 5-10nH per cm or thereabouts will soon let you know if you have a problem. Here's a link to a cascode related problem where the board pcb traces were modelled
http://hifisonix.com/wordpress/wp-co...mplifiers1.pdf |
#24 |
http://www.ti.com/lit/an/snaa045/snaa045.pdf
Paragraph 7.1 page 17 "Dertermining gate resistor values" |
#25 |
If you drove a signal straight into the capacitance of the gate it would overload the driver stage and cause instability.
http://www.murtonpikesystems.co.uk PCBCAD50 pcb design software. |
#26 |
Refer to page 7 of Bob's Mosfet paper. It is a good illustration.
All the trouble I've ever been in started out as fun......
#27 | |
I use the same technique in my currently playing MF80 amp. You're right that the sim doesn't show the oscillations, the parasitic L's are not modeled in the MOSFET models I was using. But on the bench, with my 200MHz scope I could make visible a 85MHz oscillation. In practice, a 47pF cap from drain to gate per FET was enough to have them shut up. N gate stoppers are 18 Ohm, P gate stoppers 15 Ohm. The stage is bloody fast.
Negative Feedback: The Need for Speed |
#28 |
AndrewT, you have to look at it like this and in a sudden you'll get it being very easy:
Think of the power FET as an opamp with a non-inverting input (Gate) and an inverting output (Drain). Witih opamp circuits you often put a 10pF from the output to the antiphase input. This is similar in where you connect the transistor inverting output back to its input with a HF bypass. With this, forget that drains are connected to powerlines; it doesn't change the conceptual view of the drain being an inverting output to the gate.
#29 | |
P11 shows a Zobel from Gate to audio ground. Where is the Zobel you refer to? |
#30 |
I have seen some use a ferrite bead on the gates. this should elevate the stopper impedance with frequency and thus align the N and P Mosfet rolloff (speed)
| 845 Grid stopper value | Salas | Tubes / Valves | 6 | 15th February 2008 10:00 PM |
| Gate capacitance and gate charge | rtarbell | Parts | 1 | 22nd January 2007 05:11 PM |
| Grid Stopper | dsavitsk | Tubes / Valves | 22 | 18th June 2006 12:24 AM |
| best way to generate Gate-Drain or Gate-Source short in electret capsule JFET? | capslock | Parts | 2 | 27th September 2002 08:07 AM |
