LME49830 PCB... - diyAudio
Old 27th June 2012, 08:22 PM   #1
Boscoe is offline Boscoe  United Kingdom
Default LME49830 PCB...
I know Opc has done the Wire which was very popular but I enjoy doing my layouts and I also think the LME49830 makes a very good amplifier so I'm thinking of getting these boards made for myself and selling the rest I don't need.
Audio projects and more: gswdh.co.uk
Old 27th June 2012, 08:29 PM   #2
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
neat
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa...© by Mighty ZM
Old 27th June 2012, 08:52 PM   #3
alex mm is offline alex mm  Romania
alex mm's Avatar
Hi Boscoe , IMHO
1. I don't like insects (SMD) , not so many parts , you can use TH components.
2. Heatsink if it's black line on pic , it's small, and too close to elyt caps .
3. No need to layout with dual layers (just few resistors and capacitors ) .
Some connections : clip led , muting switch are missing from PCB , and worst the OT are fake
Regards Alex.
Old 28th June 2012, 04:41 AM   #4
qusp is offline qusp  Australia
qusp's Avatar
there is zero objectively (and subjectively to me) wrong with SMD for the positions hes used them for, quite the contrary they are the better part for the job. some people will be unable to build an amplifier for themselves with available parts before they accept SMD and trust me, that time is coming
neat layout Boscoe!
also, I thought insects had many legs?
Old 28th June 2012, 06:53 AM   #5
Thanks for the feedback.
I like the SMD and don't like SMD because of their pads, I can go underneath them but can't use them as vias!
I will change the sink as I was being a bit lazy and didn't want to draw one I could find on the net as there aren't any appropriate ones in the eagle library, as well as a lot of other things!
I didn't add mute and input coupling be cause I don't like the complexity with them. The user can put some massive 1000000V audiophile tube cap on there if they want!
There's a couple of mistakes on there which I'll try and correct and I may get this sent off to be made in the next couple of weeks due to m starting a new job!
Old 30th June 2012, 04:00 PM   #6
Nisbeth is online now Nisbeth  Denmark
Nisbeth's Avatar
Interested if you have boards left over. Which FETs do you use on the output and can you include a schematic here please?.
/U.
Old 30th June 2012, 04:06 PM   #7
Outputs are:
http://products.semelab-tt.com/pdf/m...0ALF16N20W.pdf
and
http://products.semelab-tt.com/pdf/m...0ALF16P20W.pdf
I have been working off paper so I'll get something drawn up.
Old 1st July 2012, 09:02 AM   #8
effebi is offline effebi  Italy
effebi's Avatar
Great job. And I fully support your use of SMD components. And not I am not young and not newbie. I did my first traditional PCB around 1977 but from about 5 years I understood that it is defenetly time to change.
Anyway...
I see that probably you have done it in Eagle.
Would you mind to share the 49830 symbol?.
Old 1st July 2012, 10:25 AM   #9
Thanks for your replies. I'm sorry I don't have the footprint for it I just used vias and went by the pin spacing detailed in the back of the data sheet. You can make then quite easily tho. Sorry but everything is gonna be delayed a week due to me moving to London!
Old 5th July 2012, 06:52 AM   #10
LME49810.lbr
Looking for a PCB or layout for an LME49830 amp pebo Chip Amps 13 3rd February 2017 06:53 PM
Lme49830 nickarsow Chip Amps 98 16th January 2016 12:31 AM
PCB for LME49830 Melon Head Solid State 2 7th August 2010 12:46 AM
LME49830 PCB design berni8k Chip Amps 14 20th July 2009 04:45 PM
Lme49830 enzedone Solid State 6 21st February 2008 03:26 PM
Copyright ©1999-2017 diyAudio
