Amplifier Issues....
Old 26th June 2012, 08:25 PM   #1
Do It Yourself is offline Do It Yourself  United States
Default Amplifier Issues....
The amplifiers are Rod Elliott's P3A
The preamp is Rod Elliott's P97
100W x 2 stereo amplifier, the power supply is a 300VA toroidal transformer with a 35A bridge rectifier and 2 15000uf, the preamp has Rod Elliott's P05 as its power supply and a small standard transformer for it (not toroidal)
Before I put it in the aluminum chassis it was working perfectly, low noise, high stability. After i put it in the chassis i get noise and the transistors seem to try to go into a thermal runaway when have an input connected but nothing playing and raise the volume high. i hook my ipod directly to the input of the amplifier, not through the preamp, and it works perfectly
I've checked for shorts there seems to be none
i notice i get more hum when i hook the house's earth to the chassis, and most of the noise goes away when i don't hook the house's earth to the chassis and hook just the amplifier's ground to the chassis
Old 26th June 2012, 08:33 PM   #2
richie00boy is offline richie00boy  United Kingdom
Did it Himself
richie00boy's Avatar
Are your RCA sockets isolated from the chassis?
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, modules and more.
Old 26th June 2012, 08:36 PM   #3
the ground of the RCAs are tied to the chassis and the positive is insulated, i disconnected the RCA and don't use them and i still have these issues
Old 26th June 2012, 09:41 PM   #4
jaycee is offline jaycee  United Kingdom
It's definitely a ground loop. Make sure signal ground is not connected to the chassis at all. Make sure you connect signal ground and power ground at only one place
Amplifier Issues....Hide this!Advertise here!
We described a 500W amplifier in the August, September & October 1997 issues of SILIC jamesfeline Solid State 7 26th January 2011 05:25 AM
Kenwood Amplifier KA 7020 Starting up Issues! emsee Solid State 19 1st June 2008 07:17 PM
amplifier issues andyb21 Class D 2 26th June 2005 03:50 AM
