Schematic for Heathkit AR 1214
Old 26th June 2012, 03:38 PM   #1
mill23bay is offline mill23bay  Canada
mill23bay's Avatar
Default Schematic for Heathkit AR 1214
Hello
Does anyone have a schematic for the Heathkit AR 1214? I just replaced all the old electrolytic caps and both channels are still very distorted.
Thanks PeterC.
Old 27th June 2012, 06:24 PM   #2
davejames is offline davejames  United States
davejames's Avatar
Hello - I have my original AA-1214 manual that could be of assistance in troubleshootinog the amplifier portion of your AR-1214.
I could scan it into a PDF if that works for you.
DJ
Old 13th February 2014, 05:10 PM   #3
sheep is offline sheep  Canada
Anyone here can provide the schematics or manual for the Heathkit AR-1214?
Is it 15W per Ch into 8 ohms?
Old 20th April 2018, 04:15 AM   #4
Tpage is offline Tpage  United States
Did you determine what the problem with the distortion was? My right channel is distorting, left channel is OK
Old 20th April 2018, 11:06 AM   #5
indianajo is offline indianajo  United States
indianajo's Avatar
Distortion on 50 year old amps is usually oxidized pot wipers especially volume pot, oxidized inner board connectors, or dried up electrolytic coupler caps. You clean the board connectors by removing & replacing. Pots usually need replaced, as do electrolytic caps. Use the >3000 hour service live grade so you don't have to do it again, as I had to do 4 times to my 1961 dynaco amp. Before the internet I had to buy short life **** caps from the shelves of the local parts store. Now you have a choice if you look around.
Besides coupler caps, dried up mains caps can make the unit very polite, as wattage can go to 1/50 th of normal before an absolute failure. I measured a 100 W Allen amp at 2 watts on the speaker in 2015 the Monday after it went silent in a Sunday service. All new E-caps brought it right back to 20 vac on speaker.
Dynakit ST70, ST120, PAS2,Hammond H182(2 ea),H112,A100,10-82TC,Peavey CS800S,1.3K, SP2-XT's, T-300 HF Proj's, Steinway console, Herald RA88a mixer, Wurlitzer 4500, 4300
Schematic for Heathkit AR 1214Hide this!Advertise here!
AR P315 subwoofer schematic Xmitr Subwoofers 19 26th May 2018 08:53 AM
Heathkit AR-1500 cap replacements xmas111 Solid State 5 24th September 2011 01:56 AM
Best transistor substitutes for Heathkit ar-15 ar15guy Solid State 4 8th April 2008 02:21 PM
Heathkit Ar-15 one channel weak ar15guy Solid State 0 27th March 2008 01:54 PM
heathkit Schematic Glowin Plates Tubes / Valves 2 18th March 2004 12:00 AM
