Sansui G5700 Heat Problem
Old 26th June 2012, 02:11 PM   #1
Hi Speed is offline Hi Speed  Puerto Rico
Hi Speed's Avatar
Default Sansui G5700 Heat Problem
Hi
I recently purchase a Sansui G5700 receiver, everything works fine, but I worry that gets very hot in the heatsink of the power transistors even at low volume, including several small transistors as well as hot, I never read that talk about the sansui class of amplifiers class A, B or AB, is this normal or do I need to adjust the bias current that goes to 5 volts. I only use 2 speaker at 8 ohm I am planning to put 4 that it increase the heat.
Hi Speed
Old 26th June 2012, 03:04 PM   #2
destroyer X is offline destroyer X  Brazil
destroyer X's Avatar
Default Adjust 3.3 milivolts into these points you see
The output line and the power transistor's emitters..... the voltage drop over the output resistors.
This way it will be not even warm to the touch.
You may be adjusting or measuring wrong place....because correctly adjusted, the iddle power is too much small to you to feel heat into your heatsinks.
You may have other kind of troubles in your circuit.... not only bias adjustment..... but first step is to be sure each power transistor will have a voltage drop of 3.3 milivolts DC in stand by mode (without audio).... this represents 540 miliwatts of heat in each power transistor...this cannot be so big heat unless you have 40 output transistors.... and for sure you have not all these folks there.
Good luck,
regards,
Carlos
Dx unbeatable amplifiers; https://www.youtube.com/watch?v=u4tGBiqMnzQ
Old 26th June 2012, 03:25 PM   #3
Default Check your adjustment.... if you continue to face troubles, then
search for our forum friend Sakis.....he is skilled to fix these kind of amplifiers.
regards,
Carlos
Old 26th June 2012, 03:26 PM   #4
Hi Speed's Avatar
Thanks destroyer X
I did the measurements and I noticed that the left channel is on 53mv and continues to increase as temperature up to 90mv, R is 3.3mv and up to 10mv.
I have a bad copy of service manual is possible you send me a better one? my email- mc_tech@yahoo.com
Thanks Carlos
Fernando
Hi Speed
Old 26th June 2012, 04:06 PM   #5
Default 53 milivolts is a lot .... too much, this represents almost 10 watts
to each of your transistors....reduce it to 3.3 milivolts as soon as possible.
I will send the Service Manual in pdf.
regards,
Carlos
Old 26th June 2012, 04:13 PM   #6
Default Too much big Service Manual to send to you
But you can download it here:
Download Manuals for Free -- Sansui G-5700 Receiver
regards,
Carlos
Old 26th June 2012, 06:19 PM   #7
Hi Speed's Avatar
Hi Thanks destroyer X
I follow yours instructions and Problem is solved THANKS TO YOU and for a service manual
Thanks !!
Fernando
Hi Speed
Sansui G5700 Heat ProblemHide this!Advertise here!
Sansui G-5000 problem Hodgie Solid State 1 18th March 2012 01:38 AM
Sansui A-60 problem gecko Solid State 3 17th December 2010 06:04 PM
Sansui decap problem? Taiga Chip Amps 7 2nd August 2008 09:27 AM
LM4780 Heat problem Niila Chip Amps 15 2nd December 2006 09:16 PM
heat problem or not ?? arold19 Pass Labs 11 3rd May 2004 02:37 PM
