audiolab 8000A ?
audiolab 8000A ?
Old 26th June 2012, 10:31 AM   #1
glennjarrett is offline glennjarrett  United Kingdom
Default audiolab 8000A ?
Click the image to open in full size.hi just got my hands on a audiolab 8000A it has a B in the serial number and the pcb number 27400.73 anyone know what year & version this amp is its very clean inside and out . i am running a pair of b&w CDM1 NT's speakers and the source is a cambridge audio 840c upsampling 24 bit cd player just wondering if i should change the cd or speakers ? or leave as it is . also the power caps is it wise to replace them with 15000uf caps and change the bridge rectifier with 4 single high current fast recovery diodes. what other caps are a whorthwile upgrade i dont use the phono stage.
Old 26th June 2012, 11:51 AM   #2
KatieandDad is offline KatieandDad  United Kingdom
KatieandDad's Avatar
The 8000A was fundamentally a DC coupled amp so if it's working I would just be happy with it. They were built around the mid 80's.
Old 26th June 2012, 02:20 PM   #3
There are 4 signal diodes in the input LTP.
The top one mimics a current mirror.
The middle group of 3 look like some anti-saturation circuit.
Could some explain how this works?
regards Andrew T.
Old 26th June 2012, 03:38 PM   #4
I do have the full 8000A Service Manual if anyone want it please PM me. It's a HUGE scanned book. Please ask Page by Page as most ISPs will block the entire scan.
Old 22nd October 2012, 03:53 PM   #5
Default 8000a
hi i have a audiolab 8000a the mains transformer had blown the bridge rectifier had burned out and fuse blown . i have replaced the transformer and bridge rectifier and put a 100w light bulb in place of the fuse when i switch on the bulb glows then a few seconds later goes out . i have checked all four output 2x 2SC2922 & 2X 2SA1216 and driver transistors 2SA1668 & 2SC4382 out of circuit and all test ok any help please .
audiolab 8000A ?Hide this!Advertise here!
Audiolab 8000a dantzig65 Solid State 9 6th June 2011 02:48 PM
audiolab 8000a resistors dazsti Solid State 9 12th August 2008 08:35 PM
Help! Audiolab 8000A Matthewong Solid State 9 15th October 2007 06:09 PM
audiolab 8000a davephot Solid State 35 26th November 2006 10:25 PM
Copyright ©1999-2017 diyAudio
