Old 24th June 2012, 12:40 PM   #1
Default Headphones as an ultimate reference
Since headphones have fewer problems with distortion, or perhaps a different distortion profile, has anyone tried using headphones to listen to the distortion of a power amp using a jig of some sort to match level and impedance?
James
Old 24th June 2012, 12:58 PM   #2
moschfet's Avatar
Yes, about 8 ohms (6.8 ohms and 1 ohm resistor in series) as load resistance. parallel to the resistance of 1 Ohm the Headphone(300 ohm).
So I can hear more than over my speakers.
Regards http://xipix.de/
Old 24th June 2012, 10:24 PM   #3
Telstar is offline Telstar  Italy
Yes, phones like stax 007 are a good reference.
"The total harmonic distortion is not a measure of the degree of distastefulness to the listener and it is recommended that its use should be discontinued." D. Masa, 1938
Old 24th June 2012, 10:28 PM   #4
Pano is offline Pano  United States
Pano's Avatar
Sure, I've done it plenty. A resistor bridge will work fine for level match, but of course is a much easier load for the amp to drive than a real speaker. That may or may not make a difference in what you are listening for.
Take the Speaker Voltage Test!
Old 24th June 2012, 10:36 PM   #5
pinkmouse's Avatar
Of course you can, but people frequently misunderstand what a reference is. It can sound good or bad, as long as you understand exactly what it does so you can use it as an absolute comparison.
Al
I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort
Old 24th June 2012, 11:44 PM   #6
James
Please see the latest post on the thread "Does anyone make their own headphones?". I have a bicycle helmet to which is bolted [symetrically] a pair of wideband loudspeaker [small] drivers. Make your own headphones with drivers that you believe are the best.
Old 25th June 2012, 06:56 PM   #7
nowhere is offline nowhere  Israel
Originally Posted by Antoinel View Post
... I have a bicycle helmet to which is bolted [symetrically] a pair of wideband loudspeaker [small] drivers. Make your own headphones with drivers that you believe are the best.
Requirements for headphone transducers are quite different from requirements to transducers to be used in boxed speakers to be listened to in a room.
Old 25th June 2012, 07:19 PM   #8
qusp is online now qusp  Australia
is choosing a less facetious title...
qusp's Avatar
… and they have very different requirements from an amp. I find it a bit strange that people on a diy site that would normally strive for good performance would use a simple resistive divider and expect accuracy. particularly when headphone amps can be such simple circuits with very few active components
Old 25th June 2012, 07:44 PM   #9
I fully agree with you. Still; one common denominator between headphones and transducers must be the accurate and precise reproduction of music. How does a headphone maker determine it to be a Reference? I see the meaning of Reference in an Atomic Clock [cut and dry]; but not readily [hear it] with headphones or boxed speakers due to the subjectivity of music appreciation and interpretation; too many variables [and people] at play.
Old 25th June 2012, 08:32 PM   #10
My point is that boxed loudspeakers work in a room - almost free space, while, say, in circumaural headphones the transducers work in a small cavity.
In order to produce constant as a function of frequency sound pressure transducers for headphones and transducers for speakers must be different.
Reference Headphones TheBaronGroog Headphone Systems 28 17th February 2012 03:44 PM
Bose Crossover Networks - Ultimate-/Reference- or only Average Quality Standard? tiefbassuebertr Multi-Way 48 3rd December 2011 11:52 PM
Reference Monitor vs Reference Monitor SE danyele Multi-Way 0 26th January 2007 07:32 AM
Reference Sound - Reference IC's? amirmk Solid State 0 26th July 2005 07:49 PM
Any website reference for diy Audio Research REFERENCE amp and Manley Studio amp bmpa Tubes / Valves 4 19th April 2004 05:11 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
