Sony ta-fb940r humming after transformer replacement 5 connections on sec output ??
Old 24th June 2012, 09:13 AM   #1
homertooties is offline homertooties  United Kingdom
homertooties's Avatar
Default Sony ta-fb940r humming after transformer replacement 5 connections on sec output ??
Hi there everyone hope you can help me i recently had a sny ta-fb740r amplifier for fixing as per usual transformer had blown open circuit on mains side ...unusual rthing is there are 5 terminals on secondary as shown in schematic ...i dont know what the voltages are i got another with three on the output jumped the 2 ac outs to the other extra 2 and the amp hums i then connected the 2 extra to earth and still hums , hope someone can help as due to transformer being blown i dont know what the voltages were , on the board the 2 trim pots make no difference except raising and lowering the dc rails , if i connect a wire form the ov out on the transformer to the heatsink humming is louder .....The humming is there regardless of volume it gets louder when turned up to maximum , present on every input with source connected or not ..Thankyou in advance ...Also changed rectifier,big psu caps and the 4 smaller ones also .
if you strip it for parts keep them for years as soon as you get rid you will want them .....................
Old 24th June 2012, 09:29 AM   #2
Default here is the picture of power supply ..
Hi there everyone hope you can help me i recently had a sny ta-fb740r amplifier for fixing as per usual transformer had blown open circuit on mains side ...unusual rthing is there are 5 terminals on secondary as shown in schematic ...i dont know what the voltages are i got another with three on the output jumped the 2 ac outs to the other extra 2 and the amp hums i then connected the 2 extra to earth and still hums , hope someone can help as due to transformer being blown i dont know what the voltages were , on the board the 2 trim pots make no difference except raising and lowering the dc rails , if i connect a wire form the ov out on the transformer to the heatsink humming is louder .....The humming is there regardless of volume it gets louder when turned up to maximum , present on every input with source connected or not ..Thankyou in advance ...Also changed rectifier,big psu caps and the 4 smaller ones also .sony psu ta-fb740r.jpg
Sony ta-fb940r humming after transformer replacement 5 connections on sec output ??Hide this!Advertise here!
Sony TA-E88 Fet Replacement Problem zedrider Parts 31 6th January 2012 03:53 PM
sony ta-fb940r qs,left channel hardly there. paul.42 Solid State 5 6th December 2011 05:13 PM
wanted transformer for sony ta-f444es mk2 paul.42 Swap Meet 5 5th August 2011 01:56 PM
VFETs replacement, Sony TA-5650 pietres Solid State 2 7th October 2008 03:07 PM
Sony amp Ta-n611 output prob birch Solid State 0 17th August 2008 03:13 PM
