Questions about 400W mono amplfier
As that circuit is class B and looks like from the ampletos website, i'd say 0.5-5% THD.
And only four sets of 2SC5200 and 2SA1943 is not quiite enough for 400 watts into 4 ohms at the rail voltages specified, 6 pairs will be better and 8 pairs will be even better, at 10 pairs you'll have a reliable amp.
agree with djk on the Vceo issue......
we are given half of the amp, with the rail shown drop further with load? i am not aware of any convention when showing rail voltages on a schematic, is that the unloaded rail of fully loaded rail?
I upload the pictures again :) I think that this time they are okey :D
Now , i want to know how much RMS power gives each separately , and which has smallest THD . Im gonna aprecciate your answers :)
400W Amplfier Circuit - View image: 400 W Amplfier circuit
Antoher 400W Amplfiier Circuit - View image: Another 400 W Amplfier circuit
350W Amplfier Circuit - View image: 350 W Amplifier circuit
600W Amplifier Circuit - View image: 600 W Amplfier circuit
200W Amplifier Circuit - View image: 200 W Amplfiier circuit
And something to say about this schematics ?? :eek: :confused:
THD and power?
Who cares?
THD is a function of feedback, add another opamp around the whole amplifier and it will reduce the THD to vanishing levels.
Will it then sound better?
Of course not.
Power is a function of your supply quality.
Can you hear 3dB?
Just barely.
±3dB would be 250W~1000W. Now you could probably tell the difference between 250W and 1000W, but not always. In a PA situation I have heard an amplifier rated at 200W/8Ω pound harder in the base than another that could produce 750W/8Ω.
